Help! totally confused.
Discussion in 'Motorized Bicycle General Discussion' started by CycleTyrant, Aug 17, 2013.
  1. CycleTyrant
    CycleTyrant Chain Yanker
    Aug 10, 2013
    27
    So, i recently had my chain break on my motor and they guy i bought it from had a regular 1/8 bmx chain on it and im guessing thats why it broke. So i got a 415 chain, it was a little long i took 3 links off and it fits perfect (without the tension-er, i dont know if that is necessary.) So Long story short, I figured out today that there is a little rod and a ball that goes in the middle of the motor sproket? When i took the Covor plate off nothing fell out and i dont remember anything ever being in there, but now that i have the new chain on , the clutch cable wont tighten and i cant get it to move. can anyone help?
  2. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,716
    80
    yes, both rod & ball must be there - time to sweep your work area with a magnet to find them
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    The rod and ball bearing are critical parts of the clutch actuator. Without them the clutch will always be engaged no matter how tight you make the cable. If/when you find or replace them they must be well lubricated with bearing grease along with the cam in the cover.
    Good luck.
  4. CycleTyrant
    Aug 10, 2013
    27
    I dont know how i lost them, thats weird, were can i get new ones? preferably online, because im far from alot of stuff like that were i live.
  5. CycleTyrant
    Aug 10, 2013
    27
  6. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,077
    You did just fine. But pricie.
  7. CycleTyrant
    Aug 10, 2013
    27
    thats pricey? mabie you could show me were i should get it? oh and my other question was, do i need to have the tensioner on for the motor to work good? because the chain only fits without the tensoiner.
  8. Huffydavidson
    Jan 29, 2012
    1,077
    Ya, I was just doing some research for you .its called the bucking bar and ball bearing . Go to CustomMotoredBicycles. Or [email protected] $2.00 +$2.00 total--$4.00 SHIPPED YES PRICEY PAL
  9. Huffydavidson
    Jan 29, 2012
    1,077
    With BIKEBERRY shipping is extra .
  10. MotorBicycleRacing
    Jul 28, 2010
    5,716
    35
    It's a 8 mm or 5/16" ball bearing.
    Ace hardware had them for under $1 , I don't remember the exact price......
    Are you sure that the ball bearing isn't still in the hole stuck in some grease?
    I use a telescoping magnet to pull them out.
    You could make your own bucking bar out of 5/16" bar stock or an old drill bit.
  11. CycleTyrant
    Aug 10, 2013
    27
    Thanks guys, i really appreciate all of the help. hopefully there will be no problems after this one because Ive been doing more work then riding since i got it. Is the tensioner needed for the bike to run properly?
  12. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Many run without a tensioner, as long as you can get the chain aligned and adjusted with correct tension you will be good.
    Search search on the topic you'll come up with many results concerning the idler/tensioner.
    Map
  13. fatdaddy
    fatdaddy New Member
    May 4, 2011
    1,516
    I mainly use it to keep the chain up off of the frame. if the chain doesn't rub the frame andeverything is aligned properly and it works for you, leave it alone.
  14. CTripps
    CTripps Active Member
    Aug 22, 2011
    1,311
    The tensioner assembly is an 'optional' component. Some builds need it (A couple of mine do just to be sure the chain doesn't hit the chainstay) and some don't.
  15. 2door
    2door Moderator
    Staff Member
    16,308
    30
    To clear the frame and to be able to use the fat rear tire that comes on the Switchblade, the engine needs to be off-set to the left 9/16" from center. That will allow you to not use a tensioner. There is at least 2" of horizontal adjustment in the rear drop outs which should provide ample chain tension adjustment.
    The drawing the OP posted shows that the engine is not only cocked in the frame, which alone will cause chain derailment problems, but is also mounted in the center of the frame at the seat tube.
    The Switchblade, like several other chopper style bikes, is a unique frame that requires some special work to achieve a successful and reliable bike. Yes, you can simply throw an engine on one and get it to ride but you'll probably end up with the problems this man is having with his. Just saying.
  16. Will122391
    Will122391 New Member
    May 31, 2013
    90
    You can also make bucking bars if you buy a 8mm wide bolt and cut it to be 28mm long. The chain tensioner is optional. If you have the abilities to get your chain tightened and aligned without it, go for it. A tensioner is just one more thing that you have to deal with.
