Help, chain hits 2.125 tires
Discussion in 'Motorized Bicycle General Discussion' started by haste, May 1, 2011.
  1. haste
    haste New Member
    Aug 2, 2009
    131
    Hello
    Put a 80cc slanthead on a Murray cruiser. Pulled off all fenders, flipped the bars, and have everything ready to go except install drive chain. However it hits the tire.. Tried leaning motor but it just straightens out as I tighten the motor mounts.. Help?
  2. headtrama
    headtrama New Member
    Jul 8, 2010
    889
    try a number 41 chain its a little thinner then the 415 chain
  3. haste
    haste New Member
    Aug 2, 2009
    131
    Was really excited to ride today.. Now another week or so since I gotta get a new chain?
  4. tim turbo
    tim turbo Member
    Nov 18, 2009
    186
    Or you could put a skinnier tire on the back.
  5. headtrama
    Jul 8, 2010
    889
    is the chain lined up strait
  6. headtrama
    Jul 8, 2010
    889
    I run a 2.2 tire on my bike and it doesn't rub I have a schwinn cruiser .
  7. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    #41 chain isnt thinner in width it is wider and will make the chain to tire clearance worse.
  8. mapbike
    Mar 14, 2010
    5,380
    Change the tire not the chain, # 41 is a wider chain not narrower....
    Just get a 26x1.95 size tire on the back of the bike or a 26x1.75 and the clearance issue will likely go away, that is what I did on all three of my bikes I have the 26x1.95 on 2 of them and I have some very heavy duty 26x1.75 tires on another, chain rubbed the tire on 2 of them before I made the switch and they both originally had the 26x2.125 cruiser tires on them.
    narrower back tire should fix you right up, the #41 chain WILL make the problem worse the #415 chain is a 1/2 x 3/16 chain & the #41 chain deminsions are 1/2 x 1/4, it is 1/16" wider than the #415 chain.
    Check out the link here, I have these on one of my bikes which is a Huffy Beach Cruiser and they clear everything great, these are awesome tires too, low rolling resistance and good side bite when cornering on or off road, and they are sold here at a great price as well.
    Check-em out here: http://www.amazon.com/Kenda-K908-Pathfinder-Blackwall-1-95-Inch/dp/B002DX1DGW/ref=pd_sbs_sg_2
    Good luck with the build bro.
    Peace
    #8 mapbike, May 1, 2011
  9. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    Get a thinner tire.
    Worked for me. I run a 26 x 2.0 Serfas Drifter.
    Yeah, make sure the chain doesn't hit the tire or the chain stay. That's dangerous.
  10. MaxPower
    MaxPower New Member
    Jul 1, 2009
    552
    You can "re-dish" the wheel so the hub flange where the rag joint attaches is out further. Re-dish means tighten or loosening the spokes so that it moves the hub left or right. It may cause the the pedal side chain hit the wheel so you can't dish it too far. A bike shop can do it for 10 to 20 dollars.
  11. headtrama
    Jul 8, 2010
    889
    your right a #41 chain is .535
    a 415 chain is .531
  12. mapbike
    Mar 14, 2010
    5,380
    I know this because I have used the #41 chain a lot over the years on many go karts, mini bike and other things including some machinery, no biggy man that was just an honest mistake, at least you were trying to help someone out and that is more than some do at times......so you get big credit for your effort as far as I'm concerned, I wasn't trying to shoot you down with my post either I hope you understand that.
    I just wanted to make sure he didn't go out and buy something that I knew would make is current problem even worse, that's all I was doing.
    I'm in the same boat you are, I learn something new all the time, thats what makes this great forum such a blessing for us all IMHO....
    Peace
  13. headtrama
    Jul 8, 2010
    889
    It's cool by looks the 41 chain looks smaller to me anyway .
  14. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    I hate that 415.
    Why don't they just put a thinner engine sprocket on and use BMX chain?
    Life would be better.
  15. mapbike
    Mar 14, 2010
    5,380
    Some of the kits still come with the 410 chain and from what I understand they pretty much all used the thinner chain in the begginning but 410 chain is very weak in comparison to the 1/2 X 3/16 chain, so I'm glad we can use heavier chain myself, I would have probably already had a lot of broken chain issues by now with my mod'd engine is I were having to run 410/ standard bike chain.
  16. glennbo
    glennbo Member
    Aug 24, 2010
    347
    i have used washers in between the sprocket and ragjoint be carefull not to use to many or you will have issues with the coaster brake arm or rubbing the frame.
    glenn.shft.
  17. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    or you can get the smaller tire for like fifteen bucks thats what i did. the 26x2 tires are too wide. i rubbed right through to the inner wall on two of those tires before i switched. once i switched i had plenty of clearance. i wouldnt recommend anyone use balloon tires on an mb anyway. balloon tires are for different terrain like sandy or marshy, not for roads
  18. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    While it would no doubt be the easiest solution to switch to a smaller tire... I gotta say I disagree bigbutterbean, "balloon tires" work wonderfully to help absorb some of the shock of road "irregularities" (otherwise known as potholes heh), help preserve the rims & seem to corner better at the higher speeds of motorized bicycle riding, I always strive to put the largest tires I can on my builds (2.125, 2.1 & 2 currently).
    While it's true you may have chain clearance issues & they've a slightly higher rolling resistance, they've sweet road tires w/wraparound tread that's great for street, they're not all jus' for beach cruisers lol, many of the 'Death Race' guys are runnin' some pretty honkin' tires...
    *shrug* still, it's w/e works best for you and yer build ofc, to each their own ;)
  19. silverbear
    silverbear The Boy Who Never Grew Up
    Jul 9, 2009
    8,191
    12
    Bigbutterbean,
    A lot of experienced and accomplished builders and riders here on the forum would disagree with your statement about balloon tires. I like big feet under me, especially with a lot of weight up above. Heavy frame, engine, gas tank, maybe a transmission, suspension front end adds a lot of weight. I like to have the tires substantial, too, and run as wide as I can get away with. Cruiser tires are great road tires in my opinion. Notice how motorcycles have wider tires? There's a reason.
    Regarding the chain clearance issue. Smaller tire width is an option, but I'd try to find a way to keep the fat boy if possible. Sometimes the chain tensioner (if you use one) can be tweaked out a bit to redirect the chain enough for clearance. I'm guessing you have a rag joint. Is the driven sprocket dished in or out? Out will give a little more clearance from the tire.
    SB
  20. FileStyle
    FileStyle New Member
    May 27, 2008
    724
    I run Maxxis HolyRollers 2.2 tires on my Mtb.- chain clearance from the tire is about 1/8" or less, I know I can see daylight in between chain and tire. and I ve got 100's of miles on these. you have some alignment issues some where! Big tires are the way to go in my opinion.
