Hello. Please read
Discussion in 'Introduce Yourself' started by TechEd, Mar 23, 2010.
  1. TechEd
    TechEd New Member
    Mar 23, 2010
    Hi. My name is Joey. I have this project in my tech ed class where i have to fix something up. build something. so i got the approval to get an engine welded on my Haro x2.
    PLEASE anyone offer some help i have always wanted to do this
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    Welcome to the site.
    I would not weld it directly to the bike frame, but make mounts to mount an engine. Look in the DIY section of this site for help.
  3. TechEd
    TechEd New Member
    Mar 23, 2010
    Alright il check it out. how about above the back tire? i know i an new at this, but maybe it would work? but it could make the bike off balance
    #3 TechEd, Mar 23, 2010
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    If you mount a small engine above the back wheel, that acceptable. It's called a rack mount and you can use a chain saw engine, weed whacker engine or other similar small engine. 2 hp should be adequate.
  5. TechEd
    TechEd New Member
    Mar 23, 2010
    Thank you, you are helping so much =]
    how fast would my bike go is the question though.
    I would like it to go fairly fast, also i would like to be able to still petal when my gas runs out. i hear that is possible. I have almost all the equipment needed. all i need is knowledge
  6. Bikeguy Joe
    Jan 8, 2008
    11,529
    You can get 20-30 mph out of that type of engine, which is plenty fast enough for a bicycle frame/wheels.
    The type of mount set up you are talkig about lets you release the roller from the wheel so you can pedal just like a "regular bike" search for "rack mount" and have a look at the Titan, Staton and others like it for ideas. Some have a drive roller (simple to make) some have a clutch and chain. Better in my opinion if you aren't going to pedal much.
  7. TechEd
    TechEd New Member
    Mar 23, 2010
    Alright sounds good, yeah that is fast enough. thank you for taking time to help me out, if i havbe any more questions i might ask you
  8. Bikeguy Joe
    Jan 8, 2008
    11,529
    No problem, in the mean time have a look around.
  9. TechEd
    TechEd New Member
    Mar 23, 2010
    the engine i found will not work. i have to find a new one. appparently without a clutch it will go the same speed and is harder to start.
