Hello another newbie from CA
Discussion in 'Introduce Yourself' started by Starchalopakis, May 28, 2010.
  1. Starchalopakis
    Starchalopakis New Member
    May 13, 2010
    13
    Been reading around for a couple of weeks, and am looking forward to all your help!! Just got a 66c skyhawk for my jaguar. And this site has been mighty helpful already!!! Cheers!
  2. 2door
    2door Moderator
    Staff Member
    16,310
    Welcome Starch,
    There are several Jag owners here, me, for one. They make a great platform for a motorized bicycle. They are also a well built bike, stable and strong. Send us some photos of your build.
  3. Starchalopakis
    May 13, 2010
    13
    Thanks for the welcome Tom!! I will definitely get some pictures posted here soon, hopefully tommorow if I get her finished!! I have been having some trouble getting the clunch to disengage, but from what I have been reading I just need to adjust the clutch cable. I will find out tommorow!!
  4. Starchalopakis
    May 13, 2010
    13
    When I say "disengage" the clutch I mean I cannot pedal freely without engaging the motor.
  5. 2door
    2door Moderator
    Staff Member
    16,310
    Starch,
    Yes, your problem sounds like cable tension. You'll want little to no slack between the end of the cable and the clutch arm on the engine. If you've installed the small diameter spring that comes with most kits on the cable, engine end, remove and discard it. It really serves no purpose but to increase clutch lever pull. The larger diameter spring is a heat shield. Keep it. If you have any problems after tightening the cable get back to us, we'll try to help. Disregard any advice you might get about adjusting the clutch flower nut until you have good tension and are still having problems.
  6. Starchalopakis
    May 13, 2010
    13
    Thanks again Tom, and yeah I haven't touched the flower nut yet. But like you mentioned there is quite a bit of slack in the cable itself. I worked on it for a few hours today, then had to take a much needed break. But if I havent got it to work tommorow, I will post some pics and see what the next step is.
