heli coil help
Discussion in 'Motorized Bicycle General Discussion' started by nogig, Jul 8, 2010.
  1. nogig
    nogig New Member
    Mar 18, 2010
    122
    Hi guys my intake studs are stripped what size and or brand of heli coil is recomended? thanks
  2. Creative Engineering
    Sep 20, 2008
    1,668
    The threads in the jug, where the intake fastens are stripped?
    How did you manage this?
    Please explain...I won't poke fun!
    Jim
  3. nogig
    nogig New Member
    Mar 18, 2010
    122
    Well it has to do with those lovely acorn nuts and "checking" the tightness. What size are the studs Jim? I would go out and check put its raining like cats and dogs plus ive had a few and been eating some boiled peanuts. Is it ok to tap the jug? I hope i dont have a new cofee table piece
  4. Creative Engineering
    Sep 20, 2008
    1,668
    The studs are M6X1mm...
    If the studs pulled out cleanly, you can re-tap the holes 1/4"-20...no helicoils needed.
    I use a bottoming tap so that I get the maximum amount of threads for the depth of the hole. Based on SAE standards you will get a 50% thread. This is a minimum, but for this application it's fine!
    I re-tap the engine mount holes 1/4"-20 on new engines...they are also M6X1mm.
    There is no need to excessively tighten the intake fasteners...after you have re-tapped the holes 1/4"-20, install the longest bolts that you can without bottoming, even if you have to cut down a slightly longer bolt to get full thread engagement to the bottom of the hole.
    Edit: Once finished you can snug the bolts up...you don't have to baby it for fear that the new threads will strip. The new threads will not readily strip. Just snug the bolts up tight and leave well enough alone.
    Jim
    #4 Creative Engineering, Jul 8, 2010
  5. nogig
    nogig New Member
    Mar 18, 2010
    122
    thanks for the info Jim. 1/4X 20 will work just fine for me. I cant belive how much helicoils have went up
    I can see the spark plug size ones costing more but 35 bux for a wee size set. Anyays thanks alot and have a good one
  6. Creative Engineering
    Sep 20, 2008
    1,668
    You're welcome.
    Jim
