having problems adding my springer forks
Discussion in 'Motorized Cruiser Bicycles' started by buttafinguz, Mar 30, 2012.
  1. buttafinguz
    buttafinguz New Member
    Mar 7, 2012
    41
    Ive seen people with spingers on this bike (macargi huntington)and bike berry told me the one they sent should have worked. When I tried to slide the fork through thte neck of the bike it would fit through. Seemed too wide. Arent these standard? Just wondering if I could have done something wrong before I sent it back and lose my $15 on shipping. It's a greenline-heavy duty.
    Seems like its long enough if it would just go through the neck....(AAHHHHH!)
    #1 buttafinguz, Mar 30, 2012
  2. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Measure the outside diameter of your original fork, steer tube. The standard measurements are 1" and 1 and 1/8". I suspect your old fork was a 1" and the new one is 1 and 1/8". They aren't compatible.
  3. dirtyoldcrusier
    dirtyoldcrusier New Member
    Sep 1, 2010
    209
    Bicycle designer.com has springer fork accessories, depending on size you need for steerer tube, cost around 12.99-15.99. I post a link ,,, but i don't know how? Any help here guys would be appreciated. Over & out Dirtydnut
  4. buttafinguz
    Mar 7, 2012
    41
    Didnt see any that cheap
    on the site.
  5. dirtyoldcrusier
    Sep 1, 2010
    209
    Buttafinguz, Check on the left side of website, Click on Forks, then click on springer fork accessories. You should find it there. Hope this helps, Dirty dnut
  6. buttafinguz
    Mar 7, 2012
    41
    ohhhhh, now i see. thanks dirty.
  7. buttafinguz
    Mar 7, 2012
    41
    ight, this what I just measuresed. forks steering tube is 7 1/2"" long from the top to the bottom bearing race, with a 4" of threading at the top.
  8. dirtyoldcrusier
    Sep 1, 2010
    209
    Sounds like you would need to order part # 511500 / steering tube & swap out the 1 1/8" one. This would be simple to do, or you could send the one back if they don't charge a re-stocking fee, & shipping. See either way you'll spend something to fix the situation. Hope this helps, Also if sometime later on another build you could swap it back if needed a 1 1/8" . dnut
  9. buttafinguz
    Mar 7, 2012
    41
    springer
    [​IMG]
    original
    [​IMG]
    looks a lil longer too.
    [​IMG]
    #9 buttafinguz, Apr 3, 2012
  10. rustycase
    rustycase Gutter Rider
    May 26, 2011
    2,746
    Thanks for posting the link to bicyclesesigners !
    Lots of interesting parts, all in one place, and an EZ site to navigate! bonus!!!
    rc
