Has anyone tried these thumb throttles?
Discussion in 'Motorized Bicycle General Discussion' started by AaronF, Dec 2, 2009.
  1. AaronF
    AaronF New Member
    Aug 24, 2009
    389
  2. Youngbird
    Youngbird Vendor
    Dec 2, 2008
    129
    No....but I would like to try one for a handlebar mounted choke lever.
  3. doubledice
    doubledice New Member
    Nov 6, 2009
    130
    No but i totally like the idea you should try it out and let us know
    .bf.
  4. robin
    robin Member
    Nov 15, 2008
    615
    The Staton kit comes with one--its on my Subaru-Robin looking forward to trying it !
  5. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    It will fit many standard handlebars 7/8 to be exact.Just not sure about the threading for the throttle cable itself..
  6. fall_down_stand_up
    fall_down_stand_up New Member
    Apr 26, 2009
    555
    Trying to get someone else to make sure it is ok before you buy it? lol....
    I dont like the idea of a thumb throttle(never liked them on 3 wheelers)or electric bikes....Stick with the cool motorcycle twist throttle.....
    John-John.shft.
  7. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    How bout you let me know how it works lol;) I would but don't have the extra $$ for something that don't work.
    The twist throttle is decent I must say but..I ride at WOT through high traffic and now with winter coming riding through snow,ice etc I need something more 'reliable' from hand slippage.
  8. george_n_texas
    george_n_texas New Member
    Sep 4, 2009
    981
    I would think an old choke cable would work for the choke. I kinda like the idea of a stay to make the bike have a cruise control...be a bit dangerous only to be used in the wide open areas.
    237 Universal Choke Cable
  9. wes
    wes New Member
    Aug 17, 2009
    207
    I dont care forthe thumb throttle on my 4-wheeler, the twist throttle is the way to go!!!
  10. bairdco
    Aug 18, 2009
    6,334
    19
    i've got that one, but i haven't installed it yet. haven't found the right bike for it. those ones aren't threaded for the throttle cable-guide, but it wouldn't be hard to figure something out.
  11. bseelbach
    bseelbach New Member
    Jul 19, 2009
    136
    I've got one and LOVE it. It feels much more solid than the cheap plastic twist throttles.
    I think I posted some info on another thread but a few bits of advice. 1) IDK what type of threaded adapter is supposed to be used to attach to the housing and neither did the vendor. You will need to grind it a bit to get a traditional bike barrel adjuster to seat in there. Just use a dremel and check the work. 2) you will need to make a new throttle cable. I used a brake cable and followed Norman's post. Once the cable is hooked into the thumb throttle, I made an end for the slide with 49mm of cable from end sheathing to end of formed end.
  12. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    The vendor selling these on Ebay said they are threaded but didn't say the size of thread..I went ahead and ordered one anyways :D I'll let ya guys know how it goes!
  13. bseelbach
    Jul 19, 2009
    136
    It will be threaded....but for what is the question. I ground out about 1/2 of the "threads" to get a barrel adjuster to press fit when the two pieces are clamped. Any throttle length adjustment can be done at the carb.
  14. rotted
    rotted New Member
    Dec 10, 2009
    36
    anybody know if the bicycle brake handle has any clearance issues when used with the thumb throttle..... by the way supposedly twist throttles are mostly for english speaking countries... asians use the thumb throttles
  15. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    Yes you will need to adjust the brake handle or move for the clearance of a thumb throttle.By the way I'm not Asian and I love my new thumb throttle! Here is the one I purchased a week ago Throttle Thumb Assembly ATV/Quad/Pit Bike 50 110CC TT01:eBay Motors (item 390090127126 end time Jan-01-10 18:19:38 PST)
    #15 AaronF, Dec 14, 2009
  16. rotted
    rotted New Member
    Dec 10, 2009
    36
    nice.... im always scared my twist throttle will break and slide off causing me to crash when riding off road or in rough conditions, bumps, sudden stops, etc etc etc. grubee makes a flipper throttle but i have not found one for sale yet..... but yeah im considering purchasing the same type of throttle you did..... but one uestion.. with that throttle you have is it still possible to pull your brake lever until it bottoms out and touches the handle bar?? i brake brake cables otherwise.
  17. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    With my setup (Cruiser Handlebars) I had to move the brake lever over quite far to the left of the handlebars to clear the throttle casing and using it as a E-Brake.You can shorten your handlebar grips (if need to be) for the room,I didn't because it wouldn't match up with the other side..
    If you decide to use the stock metal tenisoner fitting that goes into the throttle you will mostly likely have to make a modification to fit properly into the throttle housing.Other than that..It fits nice,looks good and is a great upgrade to any MB if that is your choice of throttle :D
  18. rotted
    rotted New Member
    Dec 10, 2009
    36
    how about if you moved the throttle to the other side of the brake lever???? ohhh and a thought just popped into mind.. a wonder if a twist shifter could be used as a throttle... would it allow the carb to be opend up all the way??? hmmmm a single twist shifter wouldnt look right on a cruisers handlebars
  19. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    The throttle has a very nice response,easy,no slipping and doesn't wear out the thumb.
    Rot,It depends how your handlebars are setup,how much room etc.Main thing is adjusting for easy access and control..You could use a shifter but you'd have to grind a little off the cable end for a proper fit inside the shifter mechanism or make your own with a strong gear cable.
  20. placidscene
    placidscene New Member
    Apr 1, 2012
    318
