Hard to start my Huasheng
Discussion in '4 Stroke Bicycle Engines & Kits' started by socialdistortionkid, Dec 26, 2012.
  1. socialdistortionkid
    socialdistortionkid New Member
    May 14, 2011
    187
    It takes about 15-20 pulls to cold start my Huasheng engine with the choke, once its running it runs great.
    Brand new NGK plug.
    Fresh 87 octane gas
    I did a recent Valve adjustment but that made no difference.
    Im confused why she is so difficult to start... :-||
  2. cmanns
    cmanns New Member
    Jul 1, 2012
    132
    I never had one of these yet am waiting to buy my 49cc!
    Try 1-2 pulls full choke, then try moving it. Even harder to start? Might be your carb
    How did your old plug look? Lean?
  3. andrewflores17
    andrewflores17 New Member
    Jul 12, 2010
    479
    runs just fine when running though ???
    okay well try this gently pull the cord 2 times with it off then turn it on and give it a solid pull usualy helps for a first time pull starts on my bikes .
    is this a rear mount HS
  4. azbill
    azbill Active Member
    May 18, 2008
    3,367
    check your carb,,,the jets are known for getting clogged easily,,,especially if ethanol is in the gas
  5. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
  6. socialdistortionkid
    May 14, 2011
    187
    I appreciate the help.
    Okay thanks everyone when i get back from my vacation i will look into the carburetor. I live in CA so i have to deal with the (E10) Oxygenated gasoline.
    Its mounted in the center of a 26 inch beach cruiser.
    Spark plug is golden brown and i jetted the main jet to 0.74 because with 0.73 it bogged really badly.
  7. cmanns
    cmanns New Member
    Jul 1, 2012
    132
    ^Okay then try starting without choke?
    You sound rich :), my 2 strokes richer then **** and she rarely needs choke.
  8. beach cruiser
    beach cruiser Member
    Mar 13, 2012
    126
    I have the same problem but am too lazy to take the carb off to clean the jets. But to overcome the problem I just spray a shot of carb cleaner into the carb and the engine starts immedately.
  9. socialdistortionkid
    May 14, 2011
    187
    No difference. Still 15-20 pulls. Its very annoying.
  10. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    There is no need to remove the carburetor to clean the slow speed jet.
    See "Titan Slow Jet Cleaning" on DAX's site. The Titan and the HuaSheng have the same carburetor.
    Here: http://thatsdax.com/INSTALL_AND_SERVICE_VIDEOS_PAGE_2.html
    If that jet has even the teeniest little bit of crap stuck in it the engine will be hard to start.
  11. socialdistortionkid
    May 14, 2011
    187
    Okay guys so i cleaned and gapped the spark plug. My performance exhaust from agk came in the mail today so i installed it and now i have more bottom end power and it starts in two pulls cold. The stock exhaust mustve been clogged with carbon.
    Thanks everyone!
  12. locutus_1
    locutus_1 New Member
    Oct 31, 2010
    196
    dont need choke grab the throttle and give it a 1/4 turn and then pull start it it should fire up after 5 pulls.. remember these engines are pulling in fuel..so it takes a few pulls
  13. mirage
    mirage Member
    Oct 31, 2010
    79
    i should start a new post, don,t know how or where to do it, nothing on this site says where to write a new post,so have to follow someone else with a similar problem, this is an update. hi its me again mirage, just installed a brand new 4 stroke huasheng, it will not run no matter what i do, the new standard h/s carb would not work, won,t pull fuel into the engine, so put on a new Nt CARB still will not run. new spark plug, and new cdi with the engine, just re adjusted the tappets, ie valve lashings. found the inlet was 8 thou and th ex. 10 thou. still would not start, will start reluctantly with easy start sprayed in the carb,for a few secs, cleaned and checked the carb and jets, raised the needle one notch, stiil will not suck fuel in. does the main jet need to be bigger? looks the same as the h/s jet. my old engine would always start first time from cold, never needed the choke with the standard h/s carb, thought things would be simple with an NT carb. this is mission impossible trying to get this engine going. all new what more can one do????
    #13 mirage, Jul 15, 2015
  14. mirage
    mirage Member
    Oct 31, 2010
    79
    woopee!!!!! got it going, went out today got some fresh unleaded petrol. drained the carb, filled my tempory fuel pipe larger reinforced plastic pipe about six inches. pulled the starter cord, fired first pull. never did i think it was this simple. but there was other issues to go with it. however when i compared the old petrol with the new. the new was like pure white wine. the old was yellow like pee. don,t know how it got like that, or got contaminated. but that was why it died on me in the first place, i assume, may have been bad from the garage. but it was running fine. New lesson learned.
    but the valves where set wrong, due to the rocker screw stripping. so when i have tried the new engine and nt carb out. and when i have had a break. i will try and put the old engine back together with a new rocker arm and some. pure clear petrol. what a lot of hassle. thanks for your time guys. still cant believe fuel was 75% of the problem. bye
  15. Joemamma
    Joemamma New Member
    Apr 8, 2011
    15
    Thanks Bill and big blue for posting the video, It was the slow jet on my bike.
  16. Shady760
    Shady760 New Member
    Apr 18, 2016
    27
    I recently was riding home after work and my chain completely snapped, I immediately pulled over turned the engine off and went and got my chain off the street. It was crazy cause it literally snapped a link and not master link. So peddled myself 10 miles home. Whew!
    I have a Huasheng 49cc 4 stroke, then since the chain snapped and I don't even have 50 miles on bike yet. So decided to adjust the valves now since, it was bogging down on full throttle but would be smooth at about 75% throttle.
    Took the valve top off, moved the piston to highest point then went to adjust the valves the intake was easy but the exhaust valve seemed stuck to tight. I tried all ways of loosening it and it wouldn't loosening up at all. I then put the NGK 7 spark plug back in tightened down everything and even took the carb off with SBP air filter cleaned everything really well, made sure the jet wasn't clogged or anything put it all back together.
    I then proceeded to go take it for a test ride and seemed my pull start was super loose like almost way to easy to pull, it would retract fine. I tried putting some starting fluid in carb area and still nothing, changed spark plug back to original and same thing would turn over. Removed the pull start to check seems everything is fine minus how loosely the flywheel turns without any pressure. Last night I opened the valve top again to see if I could get the exhaust valve to adjust and still stuck really tight. Anyone have any suggestions on how to fix/repair? I'm going to contact the supplier I got the engine from and see about returning it. But more than likely anticipating they won't.
  17. fishingis
    fishingis New Member
    Dec 14, 2016
    Sounds like you have a stuck valve,if you are useing ethanol fuel this will gum up the exhust valve. You will need to take apart the motor to drop the valve and clean the gum and carbon out of the v seat,and mabe a new valve,,Fishingis:-||
