Hand grips won't fit.
Discussion in 'Motorized Bicycle General Discussion' started by BikeSmith, Jan 11, 2016.
  1. BikeSmith
    BikeSmith New Member
    Nov 28, 2015
    15
    Just got some sweet brooks slim leather hand grips over the holidays, but went to put them on today, and they won't fit. is one bigger then the other? can anyone tell me what the normal tube size on the throttle side should be? do I need to by a set for a motorcycle instead of a bike? really like the look of these. if I can get them to work. any help would be great. thanks.
  2. 2door
    2door Moderator
    Staff Member
    16,310
    Standard bicycle handlebars are 7/8" in outer diameter. You handgrips should fit if they're 'standard'. It takes a little work to get grips to slide over the twist grip throttle but it can be done.
    A little heat, hot water will work, and some lubrication, WD-40 works, but the new grip can be worked onto the throttle side.
    Just a hint, but WD-40 also works to get the old grips off. Insert a thin blade screwdriver between the grip and the handlebar and squirt in a little WD. It should twist off.
    Hope this helps.
  3. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,778
    89
    being leather, it may not stretch enough to fit
    *** motorcycles are 7/8in like bicycles - harleys are 1in
    on both, the throttle grip is 1/8in larger, so a *** throttle grip or harley left grip should fit your throttle
  4. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    You need to buy grips specifically for a motorcycle!! (one grip is bigger than the other for the throttle). ;)
  5. BikeSmith
    Nov 28, 2015
    15
    Ok I will buy a pair for a motorcycle. just really liked these. they are leather wrap over an aluminum tube. with polished aluminum collars on each end. there is a small screw on the collars. to clamp them down. like a seat post clamp. so these will not stretch like a normal grip. :(
  6. crassius
    Sep 30, 2012
    3,778
    89
    hmmm, I note that the asian bikes I mentioned are censored here ??!!??
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
    What's the bike type, ****?
