Grubee HD axle and BAND DRUM BRAKE
Discussion in 'Motorized Bicycle General Discussion' started by Midnitebiker, Feb 2, 2010.
  1. Midnitebiker
    Midnitebiker New Member
    Jan 5, 2010
    6
    Hello all, have been searching for a clue...
    Does anyone have a Picture, Close up ...of how the set up is to look for the Grubee HD axle WITH the Disc Band Brake installed...I have no idea (even after building this entire bike,LOL) how to set up the bracket, spring, cable on this rear axle.
    I have it on the bike, but I have a bracket, spring, two nuts and bolts, and a what appears like a extra lever..Thanks so much..am using the current two basic bike brakes...(not strong enought I feel)
    also would you put the band drum as a single brake or on the optional 2 in one brake lever...Thanks
    any pics or info can be posted on here or sent to my email [email protected] Thanks again:-||
  2. civlized
    civlized New Member
    Apr 28, 2009
    690
    Just in my own opinion, I would keep the other brakes also and use the two in one lever. The two in one lever may be tricky to set up with another brake. I have never done that. The band brake, for me, leaves a little to be desired. Don't get me wrong, it works, but it is not like a disc brake.
  3. Midnitebiker
    Jan 5, 2010
    6
    Thanks for pics and input...WONDERFUL forum..
    D
  4. rotted
    rotted New Member
    Dec 10, 2009
    36
    Ummm if you happen to have the freewheel version for the engine side sprocket could you tell me what the center hole on the sprocket would be the right size to fit on the thread on freewheel? and what is the width between locknuts... i have a very old bike i dont want to have to bend the frame.
  5. civlized
    civlized New Member
    Apr 28, 2009
    690
    Sorry it's taken so long to get back with you. I honestly forgot about it.
    The id of the sprocket hole is 2.5in.
    The width of the axle with the brake and pedal sprocket from inside the bike frame to the other inside bike frame is 5in on mine. I didn't have to bend mine, but it is pretty difficult install without having a tool to help spread the frame a little.
  6. rotted
    rotted New Member
    Dec 10, 2009
    36
    ahhh i had to order one yesterday just so i could find out..... if anybody wants to buy it off me send me an email
  7. GlueKill
    GlueKill New Member
    Jun 16, 2010
    26
    I used a picture similar to this to help me set up my rear brake properly. Trying to get the cable threaded through and keep the spring in place until I tightened everything down was aggravating, though.
