Got the tank done
Discussion in 'Motorized Bicycle General Discussion' started by Toothy, Sep 14, 2014.
  1. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    A while back I posted a thread about looking for a tank and plumbing a new petcock. Well here is the result. Got a 1986 moped tank, stripped it and had a local fabricator weld the petcock in the bottom for proper drainage. Holds more and looks pretty unique.
    [​IMG]
    [​IMG]
    [​IMG]
    #1 Toothy, Sep 14, 2014
  2. Rudz
    Rudz New Member
    Jun 24, 2014
    454
    Looks good. Congratulations
  3. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks! Hopefully it will hold up.
  4. 2door
    2door Moderator
    Staff Member
    16,308
    32
    Great work, Toothy. You did good. It came out nice.
    Thanks for sharing the results. What is the capacity of your tank? Looks to be close to a U.S. gallon? Maybe a little more?
  5. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks Tom, not sure on what it holds yet. The petcock is leaking a little.......
  6. turnofftheradio
    Sep 4, 2012
    242
    Nice job. I think that turned out nicely, and the color is cool.
  7. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks........
  8. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Looks really good with that color combination and nice work on getting that tank to fit and work for your project... Job Well Done
  9. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks Dave,
    I'm having issues with black flaky crap in my filter. I used a rust converter in the tank and I'm hoping that was not a mistake. I may have to pull it off and shake / use nuts and bolts again on the inside to get the stuff out.
  10. 2door
    2door Moderator
    Staff Member
    16,308
    32
    Toothy,
    You can also try sand or small pea gravel. Bee bees also work. (BB gun ammo)
    I had good luck with sandblasting. I stuck the nozzle of the blaster inside the tank through the gas cap hole and was able to get back into the corners and crevices.
    But simply shaking the tank (a lot) using the sand/gravel method also works.
    The chemical de-scalers are good but be careful and don't ruin your paint job if you use them.
    An external, in-line fuel filter should catch most of that scale you're seeing. You might have to change it a couple of times but at least it won't end up in your carburetor.
    Good luck.
  11. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Update......after the guy welded the petcock the rust converter flaked. I used some nuts and tacks to shake it free. Getting clear liquid after several shakes.....all good and well worth the workout.
    #11 Toothy, Sep 20, 2014
