Got one day of riding in!
Discussion in 'Motorized Bicycle General Discussion' started by failsatheals, Aug 20, 2013.
  1. failsatheals
    failsatheals New Member
    Aug 29, 2012
    13
    I finally got my kit together and got to ride it for a good 2-3 hours. Now when I disengage the clutch it putters and stops. If I keep petting with the clutch out it will continue to putter with the pedals, but with my limited knowledge it seems like it isnt firing the spark plug. Could I have shorted the starter? is there anyway to get a new module?
  2. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    Do you have a 2 stroke?
    To be honest, it sounds like your kill switch is stuck on or there is a wire loose in your connections from the engine to the coil.
  3. failsatheals
    Aug 29, 2012
    13
    Yes it is. I don't think the kill switch is even wired cause we weren't sure what colors went to what. Could I had shorted anything out? The white is for external power isn't it?
  4. dodge dude94
    Jun 8, 2012
    1,017
    White is for a light. Just snip or tie it off, don't attach anything to it. lol
    Even if the kill switch isn't wired, make sure the corresponding wiring coming from the engine going to the CDI box is intact and secure. Make sure your plug boot is on the plug as those kit boots are crap.
  5. failsatheals
    Aug 29, 2012
    13
    Alright. I found a few things that show how to test the cdi. If I don't have any luck ill just buy a whole new cdi unit. I tried using a screw driver in the plug and near the spark plug and no spark, but if there is loose wiring that would cause the same problem.
  6. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,427
    Might not be your problem, but I've had something similar happen a time or two when my leg has brushed the choke lever open.
    you're sure there's no spark?
  7. failsatheals
    Aug 29, 2012
    13
    I am fairly certain there is no spark, but the choke could also be a problem. I will try and mess with both of them today, hopefully I can get it running again!
  8. Arnold Layne
    Arnold Layne New Member
    Dec 3, 2010
    81
    Hey fails, throw that thing in the trunk and road trip on down here, I can probably help get you back on the road. I should have any part you may need. Still have my number? usflg
  9. failsatheals
    Aug 29, 2012
    13
    I actually still do, when would be the best time for me give you a call? Are you free today?
  10. Arnold Layne
    Dec 3, 2010
    81
    Yeah, anytime. Schedule is wide open for the most part, including today.
