Got a New bike
Discussion in 'Motorized Bicycle General Discussion' started by weekend-fun, Feb 20, 2010.
  1. weekend-fun
    weekend-fun New Member
    Jun 21, 2009
    1,001
  2. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Oh, did you buy it then? How much did you end up having to spend on it?
  3. weekend-fun
    Jun 21, 2009
    1,001
    It runs... I'll probally get a new spark plug... It was 140 (also it came with a dynamo)
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    Suh Weet!
    Now if you need info, just don't fall for the guy who sends you free info for 25 dollars from texas....
    You will of course make a new roller for it with a skate board wheel.
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    Be careful when putting it on the side stand and walking away, they have a tendency to tip over if not set just right.
  6. weekend-fun
    Jun 21, 2009
    1,001
    yep, it Falls over easily if Not placed right!
    Skateboard wheel roller.... Sounds good because the normal roller slips a lot..going to go for I ride now c'ya!!!dance1
  7. Bikeguy Joe
    Jan 8, 2008
    11,529
    Use the adjustment rod to make the roller run on the tire with enough pressure. If the "teeth" are worn off the roller, a skate wheel replacement is due. It's not too hard to do either. You can gain a few mile per hour top speed once the roller has been replaced.
  8. weekend-fun
    Jun 21, 2009
    1,001
    Yesterday I replaced the front wheel. The thing is. I rode an it worked fine. It was wet yesterday so........ Agh I'll just replace the roller! :)
  9. Bikeguy Joe
    Jan 8, 2008
    11,529
    If it rode fine (especially in the wet) then read my signature... ;)
  10. weekend-fun
    Jun 21, 2009
    1,001
    When it's dry, it starts. But when I hit the trottle, it goesand then slows down. I assume this is the sparkplug. I'll have to get a new one.
    But when it's wet, the roller dosent grip the tire. Again, I need to replace the roller with a skateboard wheel.
    Ohhh this is sooooo much fun laff
  11. Bikeguy Joe
    Jan 8, 2008
    11,529
    Did you clean the felt fuel filter that is at the end of the line inside the tank?
    I think I mentioned that before, it will cure your running problem.
