gears
Discussion in 'Motorized Bicycle General Discussion' started by neds1967, Jul 27, 2012.
  1. neds1967
    neds1967 New Member
    Jul 27, 2012
    7
    Hello to all i have a 66 cc how do i lube the gears thank youcvlt1
  2. Venice Motor Bikes
    Mar 20, 2008
    6,174
    Put a little grease on the gears... Don't use too much or the clutch will get wet & slip! ;)
  3. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    I had my 66cc engine for over a year now. I might have greased the gears 2 or 3 times the whole time i had it. i dont know if thats good or bad lol, but doesnt seem to be causing any issues. another engine that i had i accidentally put a bit too much grease on the gears once and the clutch slipped very badly.
  4. neds1967
    neds1967 New Member
    Jul 27, 2012
    7
    Thank you for getting back to me this sight is great what king of grease to you recommend thank you to all againxct2
  5. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    Any grease is better than no grease. Wheel bearing grease works good. I do mine all the time. About every 200 miles. Don't use too much. A little dab will do you. If the pinion gear gets dry it wears out pretty fast.
  6. vsavoldi
    vsavoldi New Member
    Jul 24, 2012
    78
    I am a fan of dry silicone spray or lube, you have to apply it more often but it does not collect dirt, dust and grit.
    Walmart has tubes of silicone and wax products that work great for chains.
    Either will do you fine.
    If using grease...
    Wheel bearing grease is a little thicker and will not want to fly off the gears as fast as some of the other (slicker) greases.
  7. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Dry silicone lube is not enough lubrication for the gears. You really need something a bit more like grease. As was warned above, not too much. A "Q-Tip works well for applying it and you don't need more than a 'Q-Tip will hold. Spread it evenly over the gears.
    Dry silicone has its uses but not for gear lubrication.
