Gasbike.net $200.00 GT80 Engines
Discussion in '2 Stroke Bicycle Engines & Kits' started by Keef B, Mar 1, 2016.
  1. Keef B
    Keef B New Member
    Dec 30, 2015
    19
    Sup Fellas,
    Been a while since I had a thread, but I was looking at the GT80 engines on gasbikes.net. The ones with a reed valve setup & Keihin carb clone. Has anyone purchased one of these?? If so how was the performance on it I have some telling me its bolt on ready and all it needs is a expansion chamber.. Your thoughts!!!
    Thanks in Advance
    Keef!!
  2. Keef B
    Keef B New Member
    Dec 30, 2015
    19
    No answers for anyone?? I guessing nobody has ran/running that engine kit?? Its the same kit they have on the Kings Motorbike site...
  3. Agreen
    Agreen Member
    Feb 10, 2013
    787
    Kings and gasbike are the same company from what I've gathered. And their customer support is a little lacking. Nobody I've ever talked with has ever gotten through to a representative. I bought a gt2a frame from them though, and it did arrive. A little on the late side, and I was getting worried as they provided no tracking for it, no emails saying it was shipped, but they sure charged me for it quick.
    Anyway, that engine seems like it would be ok to use. However, some things concern me.
    - "ported" That term gets thrown out a lot. What does it exactly mean? Bigger does not always mean better. Are the ports shaped properly, or are they huge and squared off where rings will snag. I would personally rather port one myself.
    - "racing" Another flashy term to get people to buy stuff. Again, what does that mean?
    - These are all components you can buy yourself, and put them on one by one. Because every engine is different, will this one be guaranteed to run the same as the last one they sold? I've never gotten an engine out of a box that didn't run. As soon as I started putting performance parts on it, it runs worse until I do some carb adjustment.
    -Break in time. This seems like the kind of engine you would want to slap on and hot dog down the road. Might not want to right yet... you still need to break that sucker in.
  4. cannonball2
    cannonball2 Well-Known Member
    Oct 28, 2010
    3,604
    96
  5. Motakitty
    Motakitty Member
    Feb 14, 2015
    445
    I had looked at that motor too but once I saw that post I quickly looked at other motors. If it seems too good to be true it probably is. Right.
  6. Agreen
    Agreen Member
    Feb 10, 2013
    787
    Eek! They called the guy, threatening him with lawsuits... but never answered the phone when i called...
  7. Neptunati
    Neptunati Member
    Jun 11, 2009
    44
    Ok I got that kit. I haven't installed it yet. So far as far as porting goes the exhaust is hogged out. In the next month I'll pull the jug (to see the porting)and inspect it, as well as the crank case( for metal shavings). Plus I want to skirt the piston. Is there a piston skirting sticky?.we.
  8. Keef B
    Keef B New Member
    Dec 30, 2015
    19
    Fellas,
    Thanks for the replys i really appreciate it. I am in the process of buying another engine, an of course we want save a penny but get the most bang for the buck. Neptunati i will be checking for your reviews, Meanwhile i will check the links you all posted an continue to research. If i find i diamond in the rough i will most definitely share it with you guys.
    Peace an Ride Safe
  9. Neptunati
    Neptunati Member
    Jun 11, 2009
    44
    Even though you went with a different engine combination I'm still going to post some pictures of this engine. Yes the port work does look like it was done kind of rushed. But it's not too bad it just needs a little finishing. The Boost Port looks kind of small and there's no window on the piston. But I plan on putting the window in the Piston to help with the reeds.
    #9 Neptunati, Mar 23, 2016
  10. Agreen
    Agreen Member
    Feb 10, 2013
    787
    That doesn't look too bad at all.
  11. Batman6583
    Batman6583 New Member
    Oct 15, 2015
    7
    Neptunati Thanks for your reviews, I really appreciate it. I am in the process of buying
    GT80 REED VALVE & KEIHIN CARBURETOR CLONE ASSEMBLY WITH PORTED CYLINDER
    Kit from gasbike, I am new and order this kit and found out that it wolud fit my motor with a type A piston , I wolud like to order a bottom end that will fit.
    I am considering:
    DAX F80 *S Rod 40mm Stroke*
    BOTTOM END *
    Any thoughts?
  12. Neptunati
    Neptunati Member
    Jun 11, 2009
    44
    http://www.pistonbikes.com/product-p/epcc15a.htm
    You're going to need this bottom end because it's the I think only one that's going to work with that top end kit might be wrong. This is the FM 80 Rod bottom end that works with that top end kit you got it will basically give you the same motor that I have
  13. Batman6583
    Oct 15, 2015
    7
    Thanks for the info.Neptunati
    Have you got your motor up and running?
    Was it difficult setting up the carburetor?
    How do it run?
    Thanks
  14. Neptunati
    Neptunati Member
    Jun 11, 2009
    44
    Not yet. I'm going to make a new build thread for my GT-80 Schwinn Swindler. I'll have lots of pictures too.
  15. Batman6583
    Oct 15, 2015
    7
    Thanks I will check it out
  16. Sam90lx
    Sam90lx New Member
    Sep 29, 2015
    62
    Any update, thinking about picking one of these up and do some clean up if needed.
  17. MaximusFunguy
    MaximusFunguy New Member
    Jun 16, 2016
    I bought one of these kits and so far it has done well. It's my first build so I have nothing to compare it to but it'll do 30 with a 240lb rider on a 44t rear 10t front. I believe it the carb needs to be jetted because it runs badly at wot. Very torquey. Just start and go. Has a hard time hitting high rpm's. could be the setup I have. The intake is quite a bit larger that the one that came with the kit. Thinking of buying a daxf80 and building a true 70 out of this GT80. Should be interesting to open it up as I just briefly inspected it before installing.
      File size:
      90.4 KB
      128
  18. mike carter 2
    mike carter 2 Member
    Nov 23, 2011
    253
    11
    neptunati pleas post pic of ported piston i ported mine after seeing the freds ported piston i tryed to port simi to his just bigger i dont think im big enough
  19. mike carter 2
    Nov 23, 2011
    253
    11
    i also put a x chamber on it made all the differance in the wourld at least twice as fast
  20. Sam90lx
    Sam90lx New Member
    Sep 29, 2015
    62
    Are you running that block / spacer that is between the cylinder and the reed or did you remove it? I'm not even sure why it is there.
