Gas tank / Petcock questions
Discussion in 'Motorized Bicycle General Discussion' started by Spoooooky, Aug 5, 2013.
  1. Spoooooky
    Spoooooky New Member
    May 31, 2013
    I bought a gas tank awhile ago. The first thing i notice is the bung were the petcock screws into has threads on the outside not the inside like my stock tank.
    So my stock petcock and my sick bike parts petcock don't fit it.
    Where can I get a petcock that fits this gas tank? (its the 2.5L peanut style)
    Would this one work?
    [​IMG]
  2. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    You might have to go to a motorcycle shop for that. I can't say I've seen a tank with the threads like that.
  3. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    there should be threads also inside that tank look again I had the same tank and it had threads inside and out! And to answer your question that will work thats the one they send in the kit with that tank!
    #3 Jumpa, Aug 5, 2013
  4. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Check with the vendor you bought the tank from first of all.
    Externally threaded petcocks have been used for years on motorcycles. You might want to check a local Japanese motorcycle shop if the seller of your tank can't help you.
    If you're fortunate enough to have a motorcycle salvage yard in your town you might find one to fit there.
    Typically those types of valves (petcocks) have a reserve position with two inlets in the tank.
    If all else fails and the bung isn't internally threaded you could run a 1/8" pipe tap into it and use a standard NPT petcock or use a 10mmX1 tap and use a kit petcock with a gasket.
    #4 2door, Aug 5, 2013
  5. Spoooooky
    May 31, 2013
    oddly enough there are no threads on the inside. I checked multiple times because it surprised me when they weren't there as it's completely smooth.
    So just making sure, that petcock I linked too will screw onto the threads on my tank?
    Sorry for making you clarify, I just hate buying stuff and having to pay to ship them back.
  6. Spoooooky
    May 31, 2013
    Hmm, thanks for the tips. I could borrow my friends tap set so I might give that a try.
  7. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    Tom is THE MAN!!!!!
  8. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,724
    82
    external threaded tanks take the newer petcocks that have a reserve setting
    the one in your link looks like it
  9. maniac57
    Oct 8, 2011
    4,486
    The petcock you show will fit the tank you show. This is the newer style tank with the petcock having a reserve position in the kits. The one you posted will fit the newer tanks but does not have the reserve position on the shut-off.
    All my recent kit tanks look like that. Better parts in my opinion. Never had any leaks with the new one, unlike the older style.
