Gas + (Stock) Cap = issues
Discussion in 'Motorized Bicycle General Discussion' started by LabRat, Mar 13, 2012.
  1. LabRat
    LabRat New Member
    Dec 24, 2011
    597
    Ok great bla bla 140mpg bla bla. More gas spews’ out the top of my china tank than makes it to ignition! Please advise......
    thx
  2. Len455
    Len455 New Member
    Mar 11, 2012
    144
    Its only temporary but uses some teflon tape.
  3. robbomberbomyea
    robbomberbomyea New Member
    Dec 10, 2011
    267
    make sure you turn gas cap till it fully locks,silly ,but it happens.or try different gas cap,local auto parts store,motorcycle shop or farm supply take your old one to compare.could also try adding or using thicker rubber seal.mine had oppisite prob too much seal not allowing tank to vent,therfor no fuel flow.hope this helps.
  4. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    If it is leaking out of the gas cap vent, this is common. Alot of folks only fill the tank to 3/4 full to prevent alot of the splash up into the cap.
    Another problem that some of the caps have is there is no direct way for any gas trapped inside the cap to drain out. Drilling a 1/4" hole in the center of the cap bottom will fix this.
    The last common problem is the gas cap gasket has a poor seal to the tank filler neck and gas leaks out this way. Some folks use 2 gaskets on one cap, some folks cut a new gasket out of leather and add it to the factory gasket or use it by itself, depending on the thickness of the leather.
  5. LabRat
    LabRat New Member
    Dec 24, 2011
    597
    Thanks for some ideas. Ill try a few and post what works for me.
