fuel additive
Discussion in '4 Stroke Bicycle Engines & Kits' started by wan37, Apr 24, 2013.
  1. wan37
    wan37 Member
    May 29, 2011
    343
    whats the best stuff to put in the gas to clean the engine and carb?
  2. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    High quality 2 stroke motor oil.
  3. wan37
    wan37 Member
    May 29, 2011
    343
    how much for 1 gallon of gas?marine 2 stroke or air cooled?
  4. nightcruiser
    nightcruiser New Member
    Mar 25, 2011
    1,180
    you want to use 2-stroke oil but NOT the marine type...
  5. Desert Rat
    Desert Rat New Member
    Jul 30, 2012
    565
    7
    Break in 7 oz per gallon ( about 18-1) after 2 tanks 4 oz per gallon
    (about 32-1) and personally I throw in about 3 small capfulls of
    marvel mystery oil but you'll hear all diff opinions about that
  6. Desert Rat
    Jul 30, 2012
    565
    7
    Why not marine? just curios
  7. wan37
    wan37 Member
    May 29, 2011
    343
    now you guys are talking about 4 strokes right that's takes straight gas right?I have a friend that has 4 stroke just wanted to clean the fuel sytem a little.Thanks
  8. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    Marine is for water cooled engines, your motor may run hotter using that.
    But I guess some marine oil is OK, from what I have read.
  9. Toadmund
    Toadmund New Member
    Jan 19, 2012
    792
    No, we assumed 2 stroke.
    Use a carburetor cleaner, spray it in and drain it out.
  10. Desert Rat
    Jul 30, 2012
    565
    7
    you gotta give us more info man to problem solve :)
    however Marvel I have used in cars with great result just follow the directions
    I used it, dad used it, granddad used it, helps prolong spark plug keeps deposits
    down and runs cleaner IMHO
  11. PAracer
    PAracer New Member
    Sep 14, 2012
    284
    The carburetor on a small engine is simple enough that you should be able to do a complete teardown, clean out, and rebuild pretty easily. A can of carb cleaners help. Just keep an eye on the order that you take it apart.
  12. andrewflores17
    andrewflores17 New Member
    Jul 12, 2010
    479
    seafoam just add it to your gas tank two stroke 4 stroke diesel seafoam will clean it all
