friction belt drives w/ link belts???
Discussion in 'Motorized Bicycle General Discussion' started by dracothered, Nov 19, 2012.
  1. dracothered
    dracothered New Member
    Jul 25, 2012
    973
    Is it possible to make a friction style primary drive with a link belt instead of the traditional V-belt? You know the type with a tension pulley that lets you engage or disengage the primary drive.
  2. bigbutterbean
    bigbutterbean New Member
    Jan 31, 2011
    2,417
    If you're describing what I think you are, then the engine idles by allowing the belt to slip the clutch. I am not sure if this is necessarily the best setup, because the belt will wear faster this way. But it should be able to be done.
  3. dracothered
    Jul 25, 2012
    973
    The set up I am talking about has two pulleys and a idler pulley that has a hand lever system that lets you engage it or not engage it.
  4. Ludwig II
    Ludwig II Well-Known Member
    Jul 17, 2012
    4,778
    72
    Look up Zenith Gradua and Rudge Multi. Manually controlled variable ratio belt drives from the 1900s.
