Free-wheeling sprocket
Discussion in 'Motorized Bicycle General Discussion' started by mifletz, Jul 11, 2010.
  1. mifletz
    mifletz Member
    Aug 25, 2009
    84
    #1 mifletz, Jul 11, 2010
  2. mifletz
    mifletz Member
    Aug 25, 2009
    84
    Staton seems to have a goodly number of small freewheeling sprockets
    Results Page
    Do any of them seem suitable?
  3. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    17
    I have a tranny similar to that one on the J-Dog. I have never looked into adding a freewheel because its a centrifugal clutch.
    J-Dog
    YouTube - DIY Motorized Bicycle
  4. NEAT TIMES
    NEAT TIMES New Member
    May 28, 2008
    1,964
    Mif
    I Use That Gear Box (a Tuff Unit) On My Shifter. How Are You Planning On Using It?? There Is Not A Freewheel Available For That Shaft That I Know Of. Remember, It Reverses Rotation! There Are Several Ways To Have A Freewheel In The Sprocket That It Drives.
    Ps You Need To Add Gear Oil. When New, They Are Shipped Dry. Ron
  5. mifletz
    mifletz Member
    Aug 25, 2009
    84
    Mine had a reasonable amount of gear grease on the gears.
    Does it need gear oil as well?
  6. NEAT TIMES
    May 28, 2008
    1,964
    mifletz
    I USE HEAVY GEAR "OIL". A SMALL TUBE FOR OUTBOARD MOTOR LOWER UNITS CAN BE FOUND AND USED. MAYBE, EVEN CHAINSAW BAR OIL COULD WORK.
    I WOULD NOT TRUST REGULAR HEAVY GREASE TO GET INTO THE BALL BEARINGS.
    IT IS A WELL BUILT GEAR BOX. CHECK YOUR CLUTCH DRUM FOR WOBBLE, THAT COULD CAUSE DAMAGE.
    ABOUT 1/2 FULL. IF THE VENT IS ON THE SIDE THAT SHOULD BE FINE. THE GEAR BOS CAN BE MOUNTED IN ANY POSITION. BUT THEN YOU MAY HAVE TO MODIFY FOR VENTING, WITH OUT A VENT IT MAY BLOW THE SEALS OUT.
    RON .cvlt1
    #6 NEAT TIMES, Aug 5, 2010
