Forward exit Horizontal dropout solution?
Discussion in 'Motorized Bicycle General Discussion' started by flatblack, Aug 18, 2011.
  1. flatblack
    flatblack New Member
    May 22, 2011
    374
    I'm looking at a frame for a my next. Everything about it is perfect....except the rear dropouts...they're horizontal which is good, front exit which is bad. I've been racking my brain to try and figure out a way to solve this. Other than hacking off the stock one's and having new welded in, I'm stuck.
    [​IMG]
  2. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    Sorry, but I fail to see a problem. Why do you consider the front exit to be bad? I'm curious really.
  3. flatblack
    May 22, 2011
    374
    Could be easily pulled out by the power of the motor. Just not ideal for a commissioned build that will be sold to someone most likely not knowing a lot about bikes. Want it to be a safe as possible. ya know.
  4. happyvalley
    happyvalley New Member
    Jul 24, 2008
    786
    Do as you think best but an average adult cyclist in reasonable shape produces far more torque at the crank than any of these little engines we commonly associate with motored bicycles.
  5. flatblack
    May 22, 2011
    374
    HHHmmm, something to consider, then.
    Thanks guys!
  6. dmb
    dmb Active Member
    Dec 4, 2010
    1,359
    drill 2 holes and close it with a strap of metal or alum. or moped axle adj from treatland /==0
