First time Motorbicycler!
Discussion in 'Introduce Yourself' started by Tippyman, Aug 6, 2010.
  1. Tippyman
    Tippyman New Member
    Aug 1, 2010
    45
    Well, my kit is due to be in next week (Grubee 2010 66cc) and I am anxious to get started.
    I plan on using the recommended (by this site) 24:1 break in for two gallons and not worry too much about its mixture or how it runs until it has a few regular gallons through it.
    Hopefully this will run reliably and be a good mode of transportation next year when I will only be working a little over 4 miles from home. Its a very hilly stretch of 4 miles though, so I need her to run well. :)
  2. tim turbo
    tim turbo Member
    Nov 18, 2009
    186
    Welcome Tippyman.Good luck with your build if you have trouble help is only a click of your mouse away!
  3. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    Welcome to the forum Tippyman. There is nothing more exciting and rewarding than assembling a kit and taking that first ride(^)
  4. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    Welcome Tippyman! Keep us informed as to how your build goes!
  5. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    Welcome to the forum. Follow the breakin procedures and it will be a durable engine.
  6. Tippyman
    Tippyman New Member
    Aug 1, 2010
    45
    Just finished the install and went for a short ride. Occasionally will have good power at 3/4 to full throttle, but with the choke off it runs like crap.
    The engine also will not idle at all. Unless I'm going pretty fast it just wont stay running. It's dead the second I put the clutch in.
    The whole "choke on/runs better" led me to believe its an intake leak. (ie. only runs good with alot of fuel.) I took the manifold off and put Honda-Bond on the intake gasket. When I went to tighten it back down, I noticed the studs were loose. I removed them completely and used bolts instead. Hopefully this'll solve my problem!
  7. bairdco
    Aug 18, 2009
    6,350
    25
    definitely an air leak. you're on the right track...
  8. Tippyman
    Tippyman New Member
    Aug 1, 2010
    45
    Well it seems I have the opposite problem now.
    It's constantly four stroking, and if the choke is on it will barely run or move. It will run poorly with occasional normal 2-stroking until the upper rpms with the choke off.
    Still no idle...
