first build,tools needed?
Discussion in 'Motorized Bicycle General Discussion' started by macattie88, Dec 4, 2009.
  1. macattie88
    macattie88 New Member
    Dec 2, 2009
    102
    im going to build my first bike and im wanting to know what i will need to complete the build as far as tools go...thanks for any info.
  2. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,646
    65
    Howdy Mac. I am sure I will forget some thing but some one will help us both out. I am guessing your mounting a 2 stroke kit? At least one 10MM wrench. A second one that ratchets will save you a lot of hair pulling. A chain breaker Or a good sized hammer, nail and a punch will also work but is a pain. Screwdrivers. For the life of me, I can not remember what size nuts are on the tensioner and tank. There are a few more. After a nap I might know what they are. lol
    Seems the most common mistake we all make during first builds is over tightening.
    post lots of pics!
    usflg
  3. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    Yes I agree watch the amount of pressure you use when putting on the nuts.Most stock studs & bolts are 10mm and I believe the tensioner bolts are a 14mm.Before you take it for a ride,recheck all of the hardware,head bolts etc. just to be safe.Good luck with your first build!
  4. Tcams
    Tcams New Member
    Oct 18, 2009
    412
    10mm will become you best friend as Fairracing31 told me. :)
  5. Creative Engineering
    Sep 20, 2008
    1,668
    macattie88,
    Do you have any tools? If so, please describe your inventory. This way we will know if you only need motorbike specific items, or a complete set to install a kit.
    Jim
  6. tyrslider
    tyrslider New Member
    Sep 26, 2008
    958
    Keep in mind that your bicycle, now a motorbike, will also require more maintenance.
    I recommend a good assortment of bicycle maintenance tools like hub wrenches, headset and bottem bracket tools in addition to the regular assortment of mechanics tools including but not limited to socket set, metric wrench set, adj. wrenches, screwdrivers, pliers, snips, allens etc. The more the better. You'll need them all at some point.
    As far as getting started or if your checking your inv. to make sure you already have it, the above is all good advice!
  7. macattie88
    Dec 2, 2009
    102
    i have a good assortment of tools already...im an electrician by trade ,but no bike specific tools...ive been searching the threads and i will basically need metric wrenchs and allens based on what ive been told so far......thanks to everyone for all the advice,this a really helpful community.shft. as far as loctite...is the red the one to use?...or blue?
    #7 macattie88, Dec 4, 2009
  8. tyrslider
    Sep 26, 2008
    958
    Actually a good Bicycle Multitool can come in handy! Cheers and welcome!
    Large Image Viewer
  9. Creative Engineering
    Sep 20, 2008
    1,668
    Use the blue locktite...the red will require heat on small fasteners: in the event you need to remove them.
    Jim
  10. macattie88
    Dec 2, 2009
    102
    thanks jim...i checked out your website and im interested in the motor mount and sproket and mount...i have a delmar...will these items help as far as ease and final finish quality?
  11. Creative Engineering
    Sep 20, 2008
    1,668
    The sprocket adapter and sprocket will definitely help with ease of assembly, and offer a far superior finished product in terms of vibration and maintenance. The engine mount offers ease of assembly, and enough vibration isolation to prevent frame cracking.
    Check the coaster brake arm for the hub model...if it's the Falcon CFE-10, I would really recommend replacing it with the shimano CB110 / CB110E.
    I assembled a Schwinn Legacy that had this hub...here's the post.
    http://motorbicycling.com/f3/falcon-cfe-10-hub-13163.html
    Jim
  12. Humsuckler
    Humsuckler New Member
    Jul 28, 2009
    458
    i blew up a falcon hub as well. the guy at bikedump in ottawa said it was inferior and they all do it....
    i forgot about what i was posting in lolz
    you need blue threadlocker. nail polish works too i have hered.
    metric wrench set from 8 to 15mm
    (i think the tank nuts are 8mm...)
    you should also remove the studs for mounting the engine and intake/exhaust and replace them with 10mm metric bolts. the studs will break, mark my words. an atv/motorcycle dealership should have metric bolts. just ask them if you can go look in their hardware bin for what you need and offer them some money.
    lockwashers of course.
    make absolutley crtain your chain tentioner is tight and correctly aligned.
    if you have a problem with teh chain rubbing the tire, you should install the sprocket with the dish facing out.
    most importntly, do not forget about the boards, and remember we can help!
    -dave
    #12 Humsuckler, Dec 5, 2009
