First break down....
Discussion in 'Motorized Bicycle General Discussion' started by Rump Rocket, Jun 10, 2014.
  1. Rump Rocket
    Rump Rocket New Member
    May 21, 2014
    26
    The throttle control twist grip gave out this afternoon, bought another cheap one off E-Bay....any suggestions that would prevent it from stripping out again....
  2. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,826
    12
    About all you can do is make sure all the screws are tight. A little dry lube in the throttle housing may help. Its always the little things.
  3. 2door
    2door Moderator
    Staff Member
    16,310
    What do you mean by "gave out"? What actually failed? The plastic part the cable wraps around is called the thimble. That's what usually breaks. The reason is too much force being applied to the twisting action and the cable being pulled very tight against the plastic. You can adjust the cable length and tension to keep that from happening again. Most any motorized bicycle twist grip throttle you find will be of about the same quality so take it easy with your replacement.
  4. Rump Rocket
    May 21, 2014
    26
    It was the thimble that gave out, I'll be readjusting the tension when the new one comes in, the length seems fine.
    By the way Tom I've been using Opti2 1.8oz per gallon it's working out very well for break-in on the new motor, the other day I pulled a plug inspection and the color was light to medium brown.
