Finger throttle?
Discussion in 'Motorized Bicycle General Discussion' started by toker_ace, Sep 16, 2009.
  1. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    Does anyone know where I can get a finger throttle for the 2 stroke china girls?My tought is with a finger throttle I can get some real soft foam grips to absorb some vibration. thanks.
  2. bseelbach
    bseelbach New Member
    Jul 19, 2009
    136
    If you want a finger pull style throttle, you could use a brake lever. I use a thumb throttle from ebay for about $15 shipped. Its not a direct replacement as you need to dremel out the throttle cable attachment hole on the throttle and make a slightly shorter cable. Here's some pics. http://motorbicycling.com/f15/first-build-diamondback-outlook-10802.html
  3. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    You can use a thumb shifter from an old mountain bike. (That's what I did).
    You buy a new thumb throttle from a shop that sells quads and they will also have
    a kill switch to replace the one in your twist throttle.
  4. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    i guess thats the problem.How to get the cable right.THe finger throttle is easy to find its the cable that has me confused.I don't think a brake cable has the right barrels or the right length. Help!
  5. bseelbach
    Jul 19, 2009
    136
    The throttle cable has one end that is the same as a brake cable. The other end that goes on the carb slide will need to me made. Follow Norm's post and it's quite easy. The OEM cable was far too long to use with the thumb throttle and even with all adjustments used to take up the slack, only allowed for maybe 1/2 throttle.
    On the thumb throttle, I dremeled the opening where the cable inserts into the opening until the adjustment screw from an extra brake lever would slide in. Once the thumb end of the cable was securely attached in the housing, I made the carb end approximately 49mm off the end of the cable housing. If I recall, cable length on that end was about 49mm and the actual barrel length was 5mm. Use a spare brake line for the modification so that you can go back to stock set up if you don't like it or it doesn't work.
    Kill switch is a simple momentary push button switch from Radio Shack mounted to an old rear seat post reflector holder.
    Hope it makes sense.
    #5 bseelbach, Sep 16, 2009
  6. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    It appears that there isn't anything out there ready to go. Only a bunch of fabricated stuff. Thats really what I need to know.Maybe there is a way to make money? LOL! Finger throttle for the china girl! Yea,,,,,,,,Yea,,,,,,,,Yea,,,,,,,, Go gett'em boys! You can thank Toker ..later!dnut
