fine tuning the 66cc
Discussion in 'Motorized Bicycle General Discussion' started by oldsurfer, Jun 27, 2010.
  1. oldsurfer
    oldsurfer New Member
    May 21, 2010
    126
    the bike runs great!!will post pictures later .is the only tuning adjusting the needle in the carb.....my bike doesn't have good bottom end...is that because its a 2 srroke? again i only have less than 5 miles on it...rickdance1dance1dance1
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    That screw is just for idle speed. You can try moving the C clip down one notch on the slide needle.
  3. Bikeguy Joe
    Jan 8, 2008
    11,529
    Plus after break in (100 miles or so) you will notice the engine runs better/smoother.
  4. jauguston
    jauguston New Member
    May 1, 2010
    142
    I am not sure Joe said what he meant. The needle clip most always needs to be in the top groove. Most come with it one groove down and the engine will be too rich at part throttle.
    Jim
  5. Venice Motor Bikes
    Mar 20, 2008
    6,216
    27
    Ride the bike more & it will start to run better & better as it breaks in!! (Then worry about tuning it!) ;)
  6. oldsurfer
    May 21, 2010
    126
    you guy are the best..thanks for the good advice
  7. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    One the throttle handle, the piece of metal the cable runs through, go to the end and loosen that nut part. This will shorten the throttle cable, and Ifound it gave me a little extra idle power I was looking for.
  8. camlifter
    camlifter Active Member
    May 4, 2009
    1,034
    ........ [​IMG]
  9. oldsurfer
    May 21, 2010
    126
    Mind Reader Explain That Better...i Want To Shorten Mine About A Foot
  10. Creative Engineering
    Sep 20, 2008
    1,668
    Mind_Reader7,
    I think you're crystal ball may be giving false readings?
    Jim
  11. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    What Joe said.
  12. oldsurfer
    May 21, 2010
    126
    Jim I Am Dieing To Get Your Billet Head When Are They Going To Be Availble Thru Pirate?
