Felt Masher
Discussion in 'Introduce Yourself' started by 3dhermit, Jul 30, 2010.
  1. 3dhermit
    3dhermit New Member
    Jul 30, 2010
    Hey guys, got my bike put together a few months ago, a felt El-Guapo , using the ampt motor mounts has anyone had a issue of them not fitting the tube snug, cause mine are not and feedback is appreciated!
  2. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    Welcome to the forum 3dhermit
    Sorry never used there mounts...
  3. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    These kits are normally designed for a steel frame with thick walled tubing. Your Felt has big diameter, thin walled frame tubes. Are your frame tubes collapsing a bit, causing the motor mount to loosen?
  4. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Won't the frames crack where they are crushed in:confused:
  5. wheelbender6
    Sep 4, 2008
    3,816
    10
    Steel won't (unless it's thin wall 853 or so). Aluminum might.
  6. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    I figured that on aluminum there was a thread covering running 1/2 round (short)lengths if steel pipe under the clamps too stop the crushing,,,I was just thinking the crushed in ring would act like a weak point like threads do on a bolt
  7. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    I think the OP is saying he's using these motor mounts designed for Felt frames
    [​IMG]
    from the vendor on the right.
  8. CoastalCruiser
    CoastalCruiser New Member
    Apr 28, 2010
    338
    AMPT is the guy who is (was?) developing an aluminum frame with a built in tank. Interestingly, Iv recently saw what appears to be the same frame being sold by Grubee.
    He's also marketing those nifty offset mounts. If your mounts are sliding around, you could perhaps drill them and the frame and insert a roll pin which would index the mount to the frame.
  9. grinNbarritt
    grinNbarritt New Member
    Jun 4, 2010
    54
    Why not just buzz a hair off where the clamps bolt together with a belt sander? just enough so they dont touch when bolted together on frame.
  10. Threesixtyg
    Threesixtyg New Member
    Dec 25, 2008
    12
    Hello felt masher, you have the wrong sized mounts, felt has two down tube sizes. They will send you the right ones. They are aware of your issue and have already mailed them to you
