Fat franks too wide??
Discussion in 'Motorized Bicycle General Discussion' started by fuzzball, Dec 9, 2009.
  1. fuzzball
    fuzzball New Member
    Sep 5, 2009
    21
    I like the looks of the creame colored Schwalbe fat franks but they only come in a 2.35 width. I've got 2.125's on my schwinn and theres only a 1/4" clearance at most to the pedal chain. The drive chain side has a good 1/2" clearance. Any way I could use em, or am I stuck with the size I've got?
  2. rotted
    rotted New Member
    Dec 10, 2009
    36
    try messing with the spacers on your rear axle. maybe you could swap the washers around.
  3. RedB66
    RedB66 New Member
    Dec 28, 2007
    1,023
  4. Venice Motor Bikes
    Mar 20, 2008
    6,215
    25
    You can 'dish' the wheel over just a little by loosening all the spokes on the pedal side 1/2 turn & tightening the spokes on the other side 1/2 turn!
    Start at the valve stem & work your way around the wheel one side at a time.
    You can also gain a little by adding a large washer in between the crank sprocket & the bearing race that holds it onto the cranks.
    Don't add too much or the pedal might hit the engine on the other side!
    #4 Venice Motor Bikes, Dec 10, 2009
  5. fuzzball
    fuzzball New Member
    Sep 5, 2009
    21
    OK Thanks for the ideas guys, I'll try to make them work someway, somehow. The quick bricks are about half the price if thats what it comes to.
  6. Venice Motor Bikes
    Mar 20, 2008
    6,215
    25
    Remember to post some pics when it's done!! ;)
  7. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    You can try just putting the tire on first to see what happens. According to your numbers it is .225" larger than the current tire. That means it will be .1125" larger on either side. It might just barely clear the pedal chain.
  8. rotted
    rotted New Member
    Dec 10, 2009
    36
    also possibly a wider spindle might help you can find them for about 10 bucks on ebay if they arent the sealed bearing type
