Fake oil tank
Discussion in 'Motorized Bicycle General Discussion' started by wheelbender6, Nov 13, 2011.
  1. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    I needed a good way to carry a small 4 oz bottle of 2 stroke oil in case I needed to gas up along the way. I found a tin containing tea bags in my cupboard that looked like it might work. I mounted it and it did the job nicely.
    [​IMG]
  2. Dirt Road Cowboy
    Sep 18, 2011
    296
  3. alienboy366
    alienboy366 New Member
    Jun 23, 2011
    114
    sweet. are yu running the sprocket on the disc brake mounting position? how is it holding up?
  4. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Nice idea WB. Looks good, plus, you have room for a couple of tea bags, just in case you run into one of our British members. Thanks for sharing the idea.
  5. diceman2004
    diceman2004 New Member
    Aug 26, 2009
    568
    had that exact same idea long ago , but couldn,t find a good enough can with a good enough lid . Glad to see someone finally made one .
    Looks real good , ( i've always liked the round oil can look )
  6. wheelbender6
    Sep 4, 2008
    3,816
    10
    The rear 39T sprocket came from Kings and it is bolted to the disk mount. It is very smooth and light.
    I agree that it is hard to find something suitable for the fake oil tank. 1lb coffee cans are too big and have plastic lids. I had also tried a shortened Pringles can.
  7. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    A 6 inch long piece of thin wall PVC pipe and 2 end caps would do real nice for this type of storage container and could probably be built for about $5.
    Glue one cap on and leave the other side to just push on - pull off and if it was to loose it would be very simple to make a small latch or retainer to keep the cap from vibrating off.
    then paint it to desired color and BAM....! there ya go!
    Peace, map
  8. wheelbender6
    Sep 4, 2008
    3,816
    10
    I bet PVC would work great. No rattles. No corrosion.
  9. maniac57
    Oct 8, 2011
    4,486
    PVC might work just as well...but tin is cooler. :)
  10. u2seek42
    u2seek42 New Member
    Aug 1, 2010
    103
    I needed a good way to carry a small 4 oz bottle of 2 stroke oil...
    I am thinking... fill the handle bars with oil, and the corks from the champagne you will drink in celebration of this step forward, will serve to keep it in... !? I gotta stop smokin this stuff!
