Extreme engine vibrations at higher rpm's...
Discussion in 'Motorized Bicycle General Discussion' started by borntofli, Oct 10, 2012.
  1. borntofli
    borntofli Member
    Jul 27, 2012
    306
    With the clutch pulled in and revving it up, anything past mid rpm's produces severe vibration-shaking...... Runs fine at lower rpm's, but above mid point the shaking becomes unbearable.....
    Driving down the road, smooth till 21 mph... after that the vibration escalates that I never go past 23 for fear of blowing it up...
    Which internal part is wearing out and causing this???
    I have about 5-600 miles on the engine...
    HT 66
    amsoil 50:1
  2. littletinman
    littletinman New Member
    May 15, 2012
    231
    What size back wheel sprocket are you using?
    this is most likely, from my understanding, due to crank balancing issues.
  3. borntofli
    borntofli Member
    Jul 27, 2012
    306
    39 tooth sprocket.......
  4. borntofli
    borntofli Member
    Jul 27, 2012
    306
    On my ride to work today, i'm only able to go 18-19mph due to severe vibrations above that....It seems to be getting worse....
    Revving in neutral, its good till approx 4000rpm and from 4-6000 severe vibration and a different exhaust sound...kind of like an exhaust leak, but not exactly....above 6000 it smooths out...
    I'm waiting for it to explode.....
    It definately doesnt have the same power it had....
    I'll be ordering a new engine today, and when I get it on I will fix this one if I can figure out what is wrong.....
    Any ideas???
  5. littletinman
    May 15, 2012
    231
    Could be the bearings. Mine did that when my bearings were going. What brand is the engine?
  6. borntofli
    borntofli Member
    Jul 27, 2012
    306
    boy go fast....
  7. littletinman
    May 15, 2012
    231
    I had all my bearings go on my BGF engine. I'm betting it is that.
  8. borntofli
    borntofli Member
    Jul 27, 2012
    306
    Is it the needle bearing engine that i want to get to replace this one????
  9. littletinman
    May 15, 2012
    231
    It's the four 6202 bearings. Two are on either side of the clutch shaft, and two are on either side of the crank weight "wheels". You'll have to take the engine completely apart to service them.
  10. 2door
    2door Moderator
    Staff Member
    16,310
    Question: Why are you reving to max rpm with the clutch disengaged? Would you do that to your car's engine, or a motorcycle, or a lawn mower? If there is a problem you're sure to find it eventually by over reving the engine. If there is no problem there will be soon.
  11. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    if its just the wrist pin bearing its not to hard to chainge if its the crank bearing you need to take everything apart
  12. borntofli
    borntofli Member
    Jul 27, 2012
    306
    I went ahead and ordered a new engine.... This is my only form of transportation so need to get it going quick.....
    Will be interesting to see what went wrong......
  13. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    my wrist pin bearing was do ing the same thing im im the prosses of doing it its hard to get myself to do it though i have the replacement out of another fail of a engine soaking now
  14. littletinman
    May 15, 2012
    231
    I just rebuilt my BGF engine twice two weeks ago. So everything's fresh in my mind if you need some help or suggestions.
    I'm in pretty much the same boat as you. I have two engines. Both almost exactly the same. When one breaks, I swap it for the other, and vice versa. Adds a bit or reliability to the hobby.
  15. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    im trying to collect the parts for a 4 stroke bike now so this one can be for fun and trying out forum things like porting and such
  16. borntofli
    borntofli Member
    Jul 27, 2012
    306
    When I start to take it apart, how would I tell if the wrist pin bearing is bad before i take it all apart????
  17. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    if the piston moves around on the rod if it jiggles and moves up and down with out the rod moving
  18. borntofli
    borntofli Member
    Jul 27, 2012
    306
    I hate to admit this but I fixed te problem w/ the vibrating.....I'm calling myself an idiot so feel free to do the same.....
    It turn out that my front motor mount stud was lose.... I know I checked all mounting connections, but somehow I missed this.....
    Got it tight and all problems are gone... I guess the shaking was foaming the gas in the carb and causing all kinds of symptoms.....
    Finally found the right size o-ring for the intake and now it runs so smooth.....
    Can't wait to get my pipe back on and I will have dirtbike like performance again....
    Thanks all for all your help, I now have a new engine coming that I dont need...Guess i'll just have to build another bike....
  19. borntofli
    borntofli Member
    Jul 27, 2012
    306
    Put my new engine on and It went smooth..... Only difference was thhat the exhayst port angle is just a bit different than my old engine...
    Had to do a little grinding on my front mount for the exhaust to clear....
    New engine runs well, idles great....
    Now to tear down the old one and see which gasket is leaking......Who has the best head and base gaskets????
