Extra Silencer
Discussion in 'Motorized Bicycle General Discussion' started by Kevron99, Apr 13, 2010.
  1. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    I added an extra silencer to an SBP exhaust. It has about 2 inches clearance from the tires (see pics). With all the adjustments I made this is the shortest way I can possibly do. If I made it pass the tires or make it extend to the left it obstruct with the bike stand if it is to the right it hits the chain. My question is with the silencer very close to the tires will it affect performance? I have not road tested it yet but have it started and it is really, really quite. So far I like it tone down. Any input is appreciated. Thanks.
    #1 Kevron99, Apr 13, 2010
  2. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    run the bike today and put 23 miles,...awesome really quiet power is not compromised with the end tip of the muffler being so close to the rear tires. Opti 2 oil and Denso Iriduim is a perfect combination though. SBP shift kit and other SBP parts really ROCKS!
  3. rockhopper
    rockhopper New Member
    Mar 20, 2010
    221
    That looks mean.
    Could you talk about your impressions of the shift kit. What's it like to ride with it? Mainly, what's the difference between the fixed gearing VS shifting gears.
    JC
  4. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    shift kit gives you the ability to have multiple gears. just like having a transmission. it gives you the advantage in hill climbing. it will makes it easier to climb and really fast. having to go over 30 mph easily on flat roads without sweating the engine. also clutch use is very minimal. unlike the fixed gears you do not need pedal fast and gain momentum to start the bike. the clutch is use only when you idle. you can get more information from this site http://www.sickbikeparts.com/catalog/. it is really fun to ride versus fixed gears.
  5. rockhopper
    Mar 20, 2010
    221
    Thanks. Could you tell me how the engine is mounted. That looks pretty cool. Did you buy that bottom mount?
  6. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
  7. rockhopper
    Mar 20, 2010
    221
    Whoa. That is some pretty serious kit. Does it dampen engine vibration or is it an adapter to the tube size?
  8. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    It is rock solid! It is pretty secure and tight. I think it does dampen the engine vibration because I do not feel it all. I am not sure though because I have never tried other mounts.
    PS. I have seen other post who has the same mount and they said their mount slipped to the left with a shift kit. I never have that problem. I will be building another Felt and will use the same mount that I have.
  9. rockhopper
    Mar 20, 2010
    221
    Hey, thanks for pointing out Pirate Cycles. Finally had a chance to go through their site today and all I can say is "Wow". This changes the way I feel about these cheap little motors.
    .shft.
    Edit: "Inexpensive" little motors. Ha ha.
    #9 rockhopper, Apr 17, 2010
  10. Wood.Neely
    Wood.Neely New Member
    Feb 16, 2010
    31
    what's the deal with the silencer?? where did you get it? how hard was install? how much $?? very interested... the bike looks sick
  11. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    Thanks! The exhaust and silencer is available at Sick Bike Parts.com. The silencer is very easy to install as it is just a hose claimp that connects it. I bought it for $5 bucks. It is very silent as all I hear at idle is the clutch and intake noise. Cheers.
