Engine wont run smooth? Please help
Flounder
65
Jacksonville Beach
I got 20 miles on a new motor maybe more, and now is acting up. It wont stay running , when i try to accelerate there is no power.. I checked the carb. and found nothing wrong with it.. The spark plug looks ok . I put a gallon of 20-1 .Then switched to 40-1 .. I'm stumped. any help would be great..
.flg.
Bikeguy Joe
Jan 8, 2008
11,837
252
up north now
What does "It won't stay running" mean?
It won't idle? It fires up then craps out? It runs so rough that you shut it off? Details man, details!
oylavabeer
214
Perth Australia
Maybe a air leak, I recently had simmilar problems and it ended up being the engine crank seal behind the little gear was not seated properly.Or the one behind the magneto , its easy so detect these prodlems as the cluth cover or the magneto cover will be covered in oil from the motor
Flounder
65
Jacksonville Beach
I got it working. A short was the problem.. The wires were not insulated enough. And shorting out.. Making the kill switch go on and off quickly, and that why it seemed to be a carb or fuel problem.. Thanks for the feedback..
