engine sprocket removal
Discussion in 'Motorized Bicycle General Discussion' started by robbomberbomyea, Mar 1, 2012.
  1. robbomberbomyea
    robbomberbomyea New Member
    Dec 10, 2011
    267
    i know ive seen this posted but cant find it. anyway im having trouble removing sprocket from starfire gt3, ive tried heating nut with torch and using rope to stop piston, turning it counter clockwise, but engine continues to turn. reason to remove, is the thin teeth on sprocket alows chain to move side to side hitting the block, im using 415 chain. dont want to use the reg. bike chain that came in kit. not even sure that the spare sprocket i have will even work on the shaft, but need it off to see. also who would have parts for this motor. thanks for any help.
  2. Ibedayank
    Ibedayank New Member
    Oct 29, 2011
    1,171
    use the puller
    [​IMG]
    to remove the nut use an impact or hit a wrench with a hammer
  3. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    The reason you keep turning the shaft, as you have used rope is that you are working against the clutch and it slips. To remove the nut, insert a piece of SOFT material (I use a rod bearing from a car) between the large and small gears on the clutch side. This will bind the engine.There are no threads on any gear or the magnet. Use the PROPER tool in above reply.
    #3 Al.Fisherman, Mar 2, 2012
  4. azbill
    azbill Active Member
    May 18, 2008
    3,367
    I have had luck with 'the sharp rap on the wrench/ratchet with a hammer' method ;)
  5. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    I made a special tool with a piece of stock chain attached to a lever, to lock the sprocket in order to unbolt the sprocket nut.
    To lock the gears on the clutch side I've found that a penny stuck between the pinion, and clutch gear works well.
  6. Al.Fisherman
    Sep 9, 2009
    1,966
    Penny (as everyone has them) works just as good. I could never see making a tool as it wouldn't be used enough to justify.
  7. robbomberbomyea
    Dec 10, 2011
    267
    thanks,ive brought my 3/8 snap-on impact home from work ill try later this evening or in morning.and i do have the clutch puller tool,but i may use a gear puller from my buddy.it is counter clockwise to remove the nut and not reverse threads right? not enough of my eyesight left to see thread direction,getting old no fun. thanks for all the help,this is great forum for advise on building motor bicycles.
  8. biknut
    Sep 28, 2010
    6,365
    None of the threads are reverse.
  9. robbomberbomyea
    Dec 10, 2011
    267
    yea, i figured it out,lefty loosey,got the retainer nut off,with socket and few wacks with screw driver, cause i forgot my 3/8 sockets for my impact at work ,but threads in sprocket need cleaned in order to get puller threaded on.work on that later.but unless the drive shaft is tapered, then the sprocket i have wont work,its larger dia. then end of the shaft. so i guess ill be lookin for a 415 sprocket to fit on my starefire motor,oh well thats that.its late here im out. thanks for the input.
