engine sits tilted
Discussion in 'Motorized Cruiser Bicycles' started by oldsurfer, Jul 6, 2010.
  1. oldsurfer
    oldsurfer New Member
    May 21, 2010
    126
    just noticed that when looking from behind the bike at the engine...it appears to be tilted down on the drive chain side..checked the rear mount studs they are fine...is this a optical illusion? what would cause this...chain too tight? there is no way to correct this ..i mean the engine monts are cast ti the case???????????zpt
  2. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    The chain is susposed to have a 1/2 to 3/4 inch of slack in the top chain ,roll the bike for a full wheel revolution,the slack needs to be at every point of the revolution ,,,,,,question,, did you get a motor w/mounts that fit the frame or are they over sized?
  3. bairdco
    Aug 18, 2009
    6,403
    50
    it usually means your chain's too tight. while the mounts are cast to fit, there's enough slop where it'll move back and forth. center your motor and make sure it's tight, then adjust your chain.
  4. oldsurfer
    May 21, 2010
    126
    i'm using the stock rear mount and a oversized front mount..will do as you say....
  5. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    #5 Al.Fisherman, Jul 8, 2010
  6. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    I understand seeing the pic
  7. oldsurfer
    May 21, 2010
    126
    al that was a great help...also i am going to make a torque brace
  8. oldsurfer
    May 21, 2010
    126
    Took The Tape Off Under The Motor Mounts..apparently The Tape Got Soft And Allowed The Motor To Slide Thover To The Left..the Frame Was Wiped Down The I Put A Level On The Head And The Side Mag Cover To Get Everything Level
  9. Al.Fisherman
    Sep 9, 2009
    1,966
    Actually that is not the way to do it. You mount the engine to the frame, not the frame to the engine. Attach the engine to the frame with the rear mount first. Adjust the height of the engine desired and then mount the front mount. Most likely a front mount has to be made/customized. I have never seen a frame with the perfect 75 degrees required to mount these engines. If you would like pictures shoot me a PM or e-mail [email protected] and request mounting pictures.
  10. drhofferber
    drhofferber New Member
    Jun 22, 2008
    307
    wrong...my old GT frame is a perfect fit for these engines...Dennis
  11. oldsurfer
    May 21, 2010
    126
    That Is What I Did Al..mounted The Back First..i'm Tellin You The Tape In My Case Got Soft And Allowed The Muffler Clamp Type Mount To Move
  12. 2door
    2door Moderator
    Staff Member
    16,310
    I agree.
    My first motorized bike was an 80s vintage Roadmaster Backstreeter. The front and rear mounts fit the 'V' frame perfectly with no modification...and I'm a stickler for proper/flush fitting motor mounts. That bike now has a little over 1600 miles on it with no engine movement or fastener failure. Cruisers with oversized and curved downtubes are another story.
  13. Bikeguy Joe
    Jan 8, 2008
    11,529
    I have a few bikes where the engine fit perfectly. The rest were an easy cheap fix.
    Never mount on tape or rubber. If anything a very hard rubber works, or I used lead sheet in the past with excellent results.
    There is also a cheap, easy way to fill any gap in an improper frame to engine fit- get some two part epoxy putty, the thick-like-clay stuff, and put it in the gap when you mount the engine. Use Saran wrap on both sides, so you can remove it easily later if need be. Mount the engine and tighten it 90% of the way, once the epoxy sets, snug down the hardware.
    #13 Bikeguy Joe, Jul 20, 2010
  14. Al.Fisherman
    Sep 9, 2009
    1,966
    What type of bike is yours? Mountain, Cruiser?? How about a picture?
  15. sradabaugh
    sradabaugh New Member
    Aug 5, 2010
  16. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    It is a common practice, but a flawed one. Using any soft material between the mounts and the bicycle frame in an attempt to reduce felt vibration actually only isolates that vibration to the motor itself instead of diffusing it through the frame, promoting excessive movement and contributing to fastener failure.
  17. Al.Fisherman
    Sep 9, 2009
    1,966
    Ain't that the truth...I NEVER use anything between the mount itself and the tube.
  18. Bikeguy Joe
    Jan 8, 2008
    11,529
    My lead sheet did eventually loosen up or compress, but after a re-tighten, it has been fine. Still, not that many miles on this particular bike, so I would recommend the solid mount technique for now.
