Engine quit running
Discussion in 'Motorized Bicycle General Discussion' started by [email protected], Apr 6, 2010.
  1. hrichmon@gmail.com
    [email protected] New Member
    Sep 25, 2009
    117
    I was helping my friend install a kit on his bike a while back. It ran good for a short period, and then one day he said it just fizzled out. I took a look at it, and he had rigged it up a little bit. I decided he needed to get rid of his rigged stuff and get new stuff and do it right. so we replaced the spark plug, the CDI and the carburetor. This is becoming an expensive headache. It still will not fire. definitely has compression, and we have triple checked the wires. clipped the connectors and spliced them up. I've done a few of these now, but I'm looking like an idiot. please help
  2. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    Check for spark, make sure fuel is getting to the carb, make sure there aren't any air leaks and I'm sure there are some other steps in trouble shooting these little motors that I can't think of at this time. I'm sure there will be some other members to offer some more suggestions for ya.
  3. hrichmon@gmail.com
    Sep 25, 2009
    117
    I have never checked for spark before. How exactly do I do that?
  4. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Pull the plug from the head, reconnect the plug wire, hold the plug on top of the cylinder head and either push the bike forward at a good pace, clutch engaged, or suspend the rear wheel and pedal it fast. Look for a spark at the plug electrodes; the little 'L' shaped part on the end of the plug and the center where the 'L' bends over. You should see a blue spark jumping between them with every revolution of the engine.
    If no spark, disconnect the kill switch from the ignition circuit and try again. If still no spark and you're using the kit supplied plug, replace it. Check the connections at the CDI and the plug boot. Get back to us with what you find.
  5. hrichmon@gmail.com
    Sep 25, 2009
    117
    I hooked up another brand new spark plug to the CDI but not the engine, and started riding, popped the clutch, held it against the block, and saw no sparks. Disconnected the kill switch, still nothing.
    I have replaced the spark plug and CDI
    I took the cover off the magneto, and all those wires seem to be connected just fine.
    Any new thoughts?
  6. crobo
    crobo New Member
    Mar 24, 2010
    94
    the mag could be shot, they are not made that well and there are some rather small wires that can burn out.
  7. Creative Engineering
    Sep 20, 2008
    1,668
    An explanation of the "rigged stuff" might lead to an answer.
    Jim
  8. hrichmon@gmail.com
    Sep 25, 2009
    117
    Ended up just swapping it with another motor that I had laying around. It runs. However the reason this other one was sitting around is because it runs at 1/2 speed. Anyone ever seen that? it sounds smooth... but just winds up slowly and runs slowly.... and has low power..... installed it on this one... and it's doing the same thing. Now I'm trying to figure out which one will be easier to fix.
    the "rigged stuff" on the other was a broken throttle handle being zip tied into place, some new spark plug cap on the CDI... god knows why....
    I'm really not diggin the MBs today :-||
  9. crobo
    crobo New Member
    Mar 24, 2010
    94
    sounds like a scared cylinder/piston maybe? loss of compression can lead to loss of power. it could be any of a million things. The new cap was prob a good idea, the stock one is horrible, hard plastic. if he didnt install it correctly that could be why. get a new wire+boot from SBP, its like 6 bucks. when you install it make sure the screw goes into the conductor and not the insulation surrounding it
    if you think the wire/cap setup you have now works, try testing it for connectivity with a volt meter
  10. Randog707
    Randog707 New Member
    Oct 18, 2009
    177
    Replace the "magneto coil" on the motor that stoped running,and on the engine running at half speed,sounds like a loss of compression.
  11. Santa_cruz_loc
    Santa_cruz_loc New Member
    Jan 15, 2010
    29
    Cant say for sure, However the stock spark plug caps from the original coil have been nothing but trouble (for me anyway) and a bad one that isn't connected correctly would definitely keep your plug from sparking. The stock "U" pin in the cap that holds the top of the plug can come loose very easily creating a bad connection. Other than that, If you still get no spark, there is some bad wiring going on. I'm only on my fifth build now, so I too am still learning this stuff.
  12. hrichmon@gmail.com
    Sep 25, 2009
    117
    swapped the magneto, and there we go..... ran great.... gave it back to my friend and it ran fine for two days, then did it again.... he changed the spark plug to a good one... fired up... then quite running..... I think I might just quite hanging out with him
  13. crobo
    crobo New Member
    Mar 24, 2010
    94
    bad killswitch?
  14. rockhopper
    rockhopper New Member
    Mar 20, 2010
    221
    Excellent diagnosis. And that's really funny.
    #14 rockhopper, Apr 26, 2010
  15. hrichmon@gmail.com
    Sep 25, 2009
    117
    took the coil from the latter and put on the former... it ran... then two days later, dude said it quit again... then he replaced the spark plug... ran for a little while then stopped again..... I’m baffled... hopefully if i turn off my phone for a few days... the problem will just go away hahaha
  16. hrichmon@gmail.com
    Sep 25, 2009
    117
    Wow... I really don’t know computers... I thought i remembered posting that a while back... sorry for the redundancies guys
  17. Bikeguy Joe
    Jan 8, 2008
    11,529
    Maybe the guy should put a little more gas in the tank when he test rides it?
