Engine Problem
Discussion in 'Motorized Bicycle General Discussion' started by psprat496, May 11, 2010.
  1. psprat496
    psprat496 New Member
    Nov 22, 2009
    161
    Ok, I posted a thread like this about a week ago but since some people on here don't know how to control themselves and their opinions the Mods deleted my thread. So here I go again and hopefully it won't be deleted.
    I've got a 66cc SkyFire hooked up to my Schwinn. Has about 300 miles on it and until recently I've ran into a problem. I used regular 2 stroke oil in my mix at about 28:1 before I switched over to Opti-2 at around 100:1. After going through a tank and a half I started to run into a weird problem. I will be going at a good cruising speed at about 30mph and the engine cuts off all power for about 1/2 a second. Then immediately after that it shoots me right back up to 30mph. Once this started to happen often, I waited for it and immediatly held the clutch in just as soon as it did happen and the engine would just start racing. I was giving no throttle but it was doing this by itself.
    Now I'm not asking for your opinion of the Opti or any synthetic oil. I just put that out there as reference.
    Any ideas what could be causing this?
    BTW, I checked my connections and magneto and everything seemed to be fine.
  2. taddthewadd
    taddthewadd New Member
    Mar 1, 2009
    339
    Back in the day I raced gas powered remote controlled cars. This would happen to us too. I think I know exactly what is happening to your engine. It is at least something to look into.
    Sometimes the fuel tank would go empty. When the very last drop of fuel would get to the carb the engine would do the same thing it would rev to redline (even though we would not be giving it any throttle) and then die. I know yours isn't dieing but it is reving really high without you giving it throttle. The reason the rc car would do this is because as the last bit of fuel reached the carb then the mixture would lean out causing it to rev with no input from the throttle. In your case maybe something is causing your engine to momentarily lean out. Maybe something is floating around in your carb and every once in a while it plugs the needle valve and then gets unstuck and your engine goes back to normal.
    If you are unfamiliar with the term "lean" or "lean out" it refers to the air to fuel ratio. Lean means there is more air and less fuel. "rich" is the opposite where there is more fuel and less air. Your engine will run its best when it is in proper balance of the two.
    Are you using a fuel filter? Maybe take the carb off and take it apart to clean it out. Once I had an issue with a carb on a dirtbike where we used a gasket sealant and a little piece broke off inside the carb and it got stuck in the needle valve.
    Hope this helps
    BTW I remember this thread from last week and I had mentioned it must be electrical but now with the new info on the engine racing it leads to my new idea.
  3. tudorvintiloiu
    tudorvintiloiu New Member
    Apr 19, 2010
    41
    Could be a short in the kill switch.. I don't have much experience with these things, but the only thing I can think of is an electrical connection somewhere. Plug? Plug wire? CDI?
    Something in this area I would say..
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    Sounds like your float is set a little too low and it's running out of fuel momentarily.
  5. Bikeguy Joe
    Jan 8, 2008
    11,529
    By going to 100:1 your FUEL TO AIR MIXTURE should be richer, not that it would cause or exaggerate the problem.
    By changing to 100:1 you may be revving the engine a bit higher and it's just running out of fuel in the float chamber.
  6. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    Sounds like the tank isn't venting properly, and when the fuel level in the bowl gets low enough, the engine quits - and then the tank vents backwards through the float bowl, and you get fuel flow back, and off you go again.
  7. bairdco
    Aug 18, 2009
    6,352
    28
    could also be vibration, causing fuel foaming. how smooth is it running at the speed it cuts out at?
  8. psprat496
    Nov 22, 2009
    161
    If I take the carb off and just spray the inside with some carb cleaner would this help at all? Or do I need to take it all apart to get a proper clean? I also ordered a new magneto that's coming sometime this week to see if that help. Also, about what bairdco said, my bike doesn't vibrate too much at cruising speed but the 2/3 times this happened I was opening the throttle up and the fuel at the top of the line started to bubble and foam. Could anyone also tell me how I can adjust my float?
  9. taddthewadd
    Mar 1, 2009
    339
    You need to take the bowl off of the carb for two reasons. One is there is a needle valve in there that you need to clean or inspect for debree. Second you need to take the bowl off to adjust the float. There is a couple of metal prongs the float pushes on. You need to bend them slightly to adjust the float.
  10. Junster
    Junster New Member
    Jun 2, 2009
    445
    I use opti also but 100 to 1 was letting my motor run too hot. You might try 75 to 1. My new top end has run on 75 to 1 since day one and I have great compression. How much viberation are you getting? The jet in the carb sometimes loosens up. You can also have fuel foaming. But I think you have a vacuum leak. Try short shots of wd-40 around the intake, carb mount, cylinder base, also check the head bolts. If you hit a leak the motor will slow for a moment. The WD temp. plugs the leak. If the motor races then it's almost for sure vacuum. Esp check the cylinder base. The motor gets hot the head bolts expand and a leak that wasn't there before suddenly is. Good Luck
