Engine for a generator
Discussion in 'Motorized Bicycle General Discussion' started by pengyou, May 5, 2011.
  1. pengyou
    pengyou New Member
    May 5, 2011
    I have an electric scooter and would look like to put a small generator on it. I have not found anything of reasonable size and weight so I am looking into the possibility of putting my own together. I have found some electric radio control motors that would work to generate electricity. Now I am looking for a small (35-50cc), lightweight compact 4 stroke engine to connect to the electric motor. Durability is also important. It will be running at virtually a constant speed.
    Any suggestions?
  2. moonshiner
    moonshiner New Member
    Apr 23, 2011
    199
    there are no real cheap 35 to 50 cc 4 stroke motors , the cheapest is the huang Seun or however its spelled , they range from about $179 to $ 250 , myself i would put down some extra cash and buy a subaru or a honda 35 cc motor ...cs.
  3. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Or an old lawn mower engine if only making a generator
  4. pengyou
    pengyou New Member
    May 5, 2011
    Thanks! The price is certainly a consideration but right now I am looking at size - compactness, and weight. I have even considered a gas powered radio control motor used to fly airplanes. They have some that are 50cc+ and a few that are 4 stroke, though oil still has to be added to the fuel - no crankcase. Weedwhacker engines tend to be compact also and only about 7 pounds...so..please continue with your suggestions. I am really trying to think outside of the box here :) FYI I can get a "huang seun" here for about US $80 There is also a factory in the south of China that makes the little Hondas...they also will make the same engine and sell it under a Chinese name. I trying my best to find that brand.
  5. moonshiner
    Apr 23, 2011
    199
    for $80 , that's cheap , i would just go with the 50cc HS 4 stroke , i forgot you were in shanghai , you can probably find every thing you need very cheap just laying about ..
    Keith
  6. Erich_870
    Erich_870 New Member
    Dec 4, 2009
    78
    This is probably the most cost effective 4 stroke you'll find in the US: Ryobi ZRRY34420 30cc 4-Stroke
    They sell just the power head, but I haven't found one that beats this amazon price.
    Erich
  7. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,825
    12
    The small, 2 stroke generators still weigh 40-50 lbs. Tough question.
  8. pengyou
    pengyou New Member
    May 5, 2011
    Hmmmm the weedwhacker has potential. As I understand, a generator is simply a gas engine hooked up to an electric motor (simplified). The weedwhacker engine is about 10 pounds. If I connect it to an r/c electric motor (same model as I will be using to power my ebike) the total weight would be about 17 pounds. I am guessing that the weedwhacker will work well at about 7,500 rmps, which is about 3,000 more than the motor on my bike will be turning. How long can I expect the weedwhacker to last if run in a constant speed mode with good filtered fuel and a synthetic oil? 500 hours? 1000 hours? Is this something that could be rebuilt - new piston, rings, bearings, etc or is it something that CANNOT be rebuilt? Please note - I am not consider the cost of rebuilding or replacing. I hope to make my ebike a land yacht and cruise through parts of China that would probably not have a 35cc gas engine available, so rebuilding would be the most convenient option if it started to lag. Would a Honda weedwhacker motor be more reliable? Can I get a better carburetor for this or other things to improve the performance and reliability? What if I want to go up a step and get a 35-50cc engine with a starter? Still, if the weedwhacker is connected to an electric motor to generate electricity, I can use the electric motor in "motor mode" to work as a starter for the weedwhacker engine. Lots of questions here :) I hope to implement this in the summer but I have to make some decisions now about how to use the space on my ebike. I want to buy the lithium batteries now - at US$ 400 an expensive proposition - and i won't be able to change my decision after I make it. The batteries come in a variety of shapes.
    Here is a pic of a bike like me, just so that you know what I am beating one :) http://item.taobao.com/item.htm?id=9945325151
    #8 pengyou, May 7, 2011
  9. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    How does the oil level work on a 4 stroke weed wacker,it is held at various angles and oil level would change a lot???
  10. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    Giro-scoping Conuiter Valve. ;)
  11. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    GH do you know a site that shows the exploded/see-through view of a WW 4 stroke,I clicked a bunch on google but none the pic results I needed,I want to see that giro-scooping part
  12. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    Maybe you could try a locomotive style drivetrain.
    They use a large diesel gennerator to power the electric motor driven wheels.
    They use the throttle on the generator to control wheelmotor's power and speed. Very simple system with minimal circutry to engineer.
