Ebike build parts White Industries UHD Ultra heavy duty Freewheel and much more
UtiliD
Custom Ebike build kit White Industries freewheel, tensioner CYC parts Bottom Brackets Crank arms
Many of these parts are from SickBikeParts.com. They are no longer in business, but other ebike part websites like Luna cycle , Electrify Bike Co, CYC, and Cyclone offer the same or similar parts. Some were meant for middrive kits but can work with others.
Shimano Alfine tensioner and the 3 sets of cogs next to it, red gold and black, are not included in this sale.
Most of these parts were for a build I was collecting parts for. Mainly a custom full suspension Ebike build.
New White Industries Ultra heavy duty UHD freewheel
NewChainring freewheel adapters for White Industries Super HD freewheel (4 total), 2 different size 5 star adapters 130BCD(1) & 110BCD(1) and
4 star adapter 104BCD(2)
New Bottom brackets, (2 different models); 1 Bottom Bracket Cartridge 226 mm, square tapered extra long spindle, with keyed drive side spindle to fit freewheel adapter, and 1.37", with freewheel adapter, fits White Industries freewheel.
2nd is 150mm ISIS Bottom Bracket Cartridge for 68-83+ shell
Bottom bracket washers
Crank arms with builtin freewheel adapter, BLACK Cranks - Freewheel ISIS Crank Set
Freewheel adapters(see pictures, most are for the 30mm BMX size smaller thread freewheels, the one that works with the 1.37" freewheel is attached to the wide spindle bottom bracket if I remember my picture correctly)
New Freewheels(on top of the White Industries freewheel) all 30mm BMX thread standard. Some came from SICKBIKEPARTS.COM some from Amazon or ebay.
The sealed bearing no brand freewheel came from an ebay seller in China its 16t
Noname freewheels from SickBikeParts.com (3) are 13t narrow, 14t wide, and 14t narrow that needs service or the mechanism is faulty.
The last freewheel I know as a DNP style freewheel(same wrench/tool interface as the sickbikeparts freewheels), but doesn't say DNP it says Cold-Forged Technology on one side and Tri-diamond on both sides.
Vintage preowned Chain tensioner / chain guide. RooX High Performance Chain Control System Roller Coaster chain control system designed by Danny Herz, with comes with New Stone ISCG-03 ISCG-05 bottom bracket adapter. The chain control system is designed for ISCG-03 Tabs but the stone adapter allows it to connect to ISCG-05 tabs or be connected by the bottom bracket. If you're not familiar It's a mid frame chain tensioner/guide. I got this because I was going to do a full suspension bike build with an internal geared hub(IGH) drivetrain. I was going to refinish it with black power coating, they are rare. It didn't come with the original top guide, so I adapted a guide from a different system. I'm also including aluminum tensioner cogs, and steel 410(single speed wide chain) tensioner cogs I bought to possibly adapt this tensioner.
New A bunch of bolt on brackets for custom battery, controller, or other component mount on bike.
New Battery or controller bag
Preowned Tools for Freewheel removal and disassembly
Park Tool SPA-1 freewheel pin spanner
Park Tool SPA-2 freewheel pin spanner
No-name adjustable pin spanner
A freewheel tool(labeled "Ledin VAR 187/6") I used a grinder to shape, so it would fit White Industries Freewheels because their tool was stupid expensive at the time I was shopping for it.
Park Tool FR-6 freewheel Tool
DNP freewheel Tool for their 30mm interface freewheels
Ice Tools torque wrench/bit driver
Vintage "Sugino Chain Wheel" Crank removal tool
Bottom bracket removal tool I cut so 5/8" spindles would fit through it
Misc other hardware, including rack mounts.
Will post link for listing on ebay below.
If the link doesn't work go to ebay and search
And it will come up.
If you click on my seller icon you can see the rest of the bike stuff I have listed on ebay
I'm in Clearwater Florida if someone wants to pick it up locally
