easy fix for bicycle sprocket clearance....
Discussion in 'Mounting Techniques for Bicycle Motors' started by Tucson_Toast, May 19, 2016.
  1. Tucson_Toast
    Tucson_Toast New Member
    May 9, 2016
    8
    Being my first build' i was having trouble figuring out how to mount the engine high enough on the frame to clear the bicycle sprocket. resulting in the creation of a frankenstein type mount.It would be safe to say' after having 2 mounting bolts snap off in the block and ending up with an engine in my lap.......Suddenly simple seemed to be the solution.I just put another rear mounting bracket in the front and used the head threads from a junker instead of the short stock mounting bolts. Im sure it has been done before but it works like a champ for me and honestly am looking for any feedback as to why i should/shouldnt be running this front motor mount this way..shft.
  2. 60weight
    60weight New Member
    Sep 15, 2011
    104
    Well, Your drive chain clears the frame fine looks like...
    Both mounts look strong...and these 48cc engines dont vibrate bad...
    And Your front tube is the smaller size,engines got the big size so You solved that just fine..
    Id say You did great!
    #2 60weight, May 19, 2016
  3. bluegoatwoods
    bluegoatwoods New Member
    Jul 29, 2012
    1,577
    Yup! Looks good to me.
    You say you're a newbie? Then you're a newbie who knows how to use your head.
    You'll want to keep an eye on those studs and make sure they don't work loose. But that's true with any build.
    Your drive chain looks just a bit slack to me. You ought to do something about that.
  4. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    10
    Looks good toast, maybe we will run into each other on the streets of Tucson some day.
  5. mogollonmonster
    Aug 26, 2015
    472
    Toast, the only improvement I can offer would be to replace the studs with the highest grade tempered American hardware. But that's about it really, and only If you want to, I'm sure they'll work.
    Dave, I didn't realise you're from AZ, yay us!
  6. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    10
    Yes sir, born and raised Arizonan
  7. george_n_texas
    george_n_texas New Member
    Sep 4, 2009
    981
  8. maniac57
    Oct 8, 2011
    4,486
    I agree. Looks just fine, and light years better than some of the stuff I've seen.
    Keep an eye on all the hardware the first few weeks until everything takes a set.
    Then you can check every few weeks
  9. Tucson_Toast
    May 9, 2016
    8
    Looks pretty sturdy. Have you had any experience with one. Up to this point I've been doing my best to reduce the number of moving parts. hence no tensioner
