Dual petcock?
Discussion in 'Motorized Bicycle General Discussion' started by MatCauthon137, Aug 11, 2013.
  1. MatCauthon137
    MatCauthon137 New Member
    May 12, 2009
    49
    Ok, so I had this crazy idea. Mount the stock gas tank on front, and I found a flat rear gas tank. The problem is hooking up the secondary tank. I'd need a y shaped petcock and 3 hoses so I can shut off one tank and turn on the other...
    Can't find such a creature however. Anyone have any other ideas or know where to find these?
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Why not just put a petcock on each tank and then all you'd need is a 'Y' barb fitting to join the two lines to the carburetor. You don't need a 'Y' petcock.
    Keep in mind that your rear tank will need to be mounted high enough that the fuel outlet is higher than the carburetor inlet.
  3. dumpstercrusher
    dumpstercrusher New Member
    May 20, 2013
    261
    you can find a Y shape connector at lowes. if it doesnt fit thru the hose, you can heat the end of the hose to expand it and then slide it on.
  4. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    Any t-connector will work, along with each tank's petcock.
  5. MatCauthon137
    May 12, 2009
    49
    Awesome guys, thanks. I got so focused on the dual that I didn't even think of that.
  6. VIKTR
    VIKTR New Member
    Jan 10, 2012
    193
    I did this a week or so ago
  7. KenX
    KenX New Member
    Apr 20, 2013
    252
    Extremely cool.
  8. dumpstercrusher
    May 20, 2013
    261
    did you make that gas tank? looks custom and a good job too!
  9. VIKTR
    VIKTR New Member
    Jan 10, 2012
    193
  10. 5-7HEAVEN
    Aug 2, 2008
    2,364
    LOL, betcha that T-fitting was easy to find, huh?dance1
  11. VIKTR
    VIKTR New Member
    Jan 10, 2012
    193
    Home depot
    The tough part was getting the hose to fit as the fitting was a couple sizes too big.
