drill your own sprocket?
Discussion in 'Motorized Bicycle General Discussion' started by beerbattered, Jan 26, 2010.
  1. beerbattered
    beerbattered New Member
    Jan 1, 2010
    34
    Is it possible to buy a sprocket without holes? I'm going to mount it on the disk mount and I don't think I have to have an adapter for any other reason so why not eliminate it by drilling proper holes?
  2. Elmo
    Elmo New Member
    Sep 3, 2009
    749
    Check out Azbills threads. I bought a wheel from him that is set up that way. It appears that he took a regular sprocket and drilled it to match the holes on the disc brake rotor and cut the center out. PM Azbill for more info.
  3. Elmo
    Elmo New Member
    Sep 3, 2009
    749
    Forgot to post pics.
  4. RedB66
    RedB66 New Member
    Dec 28, 2007
    1,023
  5. azbill
    azbill Active Member
    May 18, 2008
    3,367
    all I did was cut the 9 hole pattern from hole to hole with a grinder
    then centered the rotor (160mm) on the sprocket and marked the holes
    I found the disc mount was to far out and wouldn't line up with engine sprocket
    it is spaced closer to spokes with 2 nuts (I used washers until I got the spacing figured out)
  6. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    How could I go about drilling the middle hole of a sprocket for a wider diameter?
  7. RedB66
    RedB66 New Member
    Dec 28, 2007
    1,023
