Drill fuel tap?
Discussion in 'Motorized Bicycle General Discussion' started by Pcain, Jan 31, 2013.
  1. Pcain
    Pcain New Member
    Apr 30, 2012
    33
    Hi guys,
    I'm real stumped with my engine. The company I bought it off had a recall over Christmas. I sent back my engine and had the "updates" installed. I'm told it was new bearings etc. I've tried running the engine and it is just sluggish. Nothing like it was. Carb is the same model but looks new, cylinder looks new also. Where I set the clutch is off also. Probably a different engine.
    Anyways, starting is a struggle. It doesn't like to idle and it's struggling when riding WOT. The fuel tap doesn't seem to be letting much fuel out either. Can I drill straight through this new one? Open it up? It has a large nipple bit the screwed in part has only a 2mm hole at best.
    I'd appreciate any input.
    Cheers
    Chris
  2. maniac57
    Oct 8, 2011
    4,486
    Lower the carb needle one groove and see if it helps. These motors are usually so rich from the factory they will barely run. If this helps, ride it until it starts smoothing out. Break in usually takes five or ten tanks.
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    I think we need to know what engine you have before offering any advice.
    Sorry, maniac57, but that's a fact. 2 stroke or 4? All too often we assume the OP is talking about a Chinese 2 stroke. That's not always the case. The advice needs to apply to what engine/carburetor the person has.
  4. maniac57
    Oct 8, 2011
    4,486
    My bad. I see smoke everywhere...
