Don't laugh but...
Discussion in 'Motorized Bicycle General Discussion' started by Toothy, Apr 22, 2014.
  1. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    How do you ride one of these things? I've ridden stick shifts, dirt bikes etc. but before I take my build out I want to make sure I have the basics down. If there is a sticky let me know.
    I’m guessing you ride till about 7-10 mph then drop the clutch and off you go...but....when you slow down / come to a stop what then? Do you pull the clutch let it run, peddle and then drop the clutch again?
    Sorry if this sounds as green as I think it does.
  2. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    You got the first part right, second part is dependent on the rider. When coming to a stop, I pull the clutch, coast then brake. Leaving a stop I pedal, gas up and slip the clutch and I'm off.
  3. massdrive
    massdrive New Member
    Oct 3, 2013
    454
    No problem... I assume you have a 2 stroke engine. When you go to slow for the engine to run just pull in the clutch and pedal. Same thing when you stop. I usually shut the engine off when waiting for a traffic light, but than again I live in the Mojave Desert. Your clutch lever should have a lock position if you don't want to hold the clutch lever in. When the engine bogs down while ridding up hill simply start pedaling to assist the engine, it's called "pedal assist". When coasting down hill and when decelerating in general pull the clutch lever in and let the engine slow to an idle. When decelerating your engine is running high RPM's, but since you are off the throttle it is starving for fuel... fuel is lubricant... insufficient amount of fuel + high RPM's = broken engine
    I suggest you go to the newby thread and learn how to maintain your bike. A well maintained bike is a safer more reliable bike to ride.
  4. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks guys.....I'll check out the noob section.
  5. allen standley
    Oct 22, 2011
    791
    19
    No laughing, All is good! Here's what I give to new riders.
    This is a motorized bike.
    Unlike a Motorcycle with a clutch, gears and kick or electric start. Unlike a motorcycle the clutch is not featherable. Meaning you cannot start from a dead stop by slowly releasing the clutch. To start a motorized bike you must pedal up to speed and release / engage the clutch lever on left side handlebar of bike. Once the engine starts you will manipulate speed with the twist grip throttle control on right side of handle bar. In order to stop safely at a stop light or stop sign you must disengage the clutch (Squeeze) to prevent stalling the engine.
    You must Disengage (Squeeze) the clutch at every stop.
    You must pedal your bike up to speed then release / engage your clutch to be on your way again.
    There is a clutch lock button on the clutch lever which you can depress should you wish to leave the engine running while stopped.
    Sorry to be redundant everyone. I just used this to help another new rider understand. It was rite here on my desktop.
  6. CTripps
    CTripps Active Member
    Aug 22, 2011
    1,311
    No worries, we were all new once. (Something that seems to get forgotten many other places out there).
    Follow the advice above and you shouldn't have any problems. I'll add my 2¢ worth.. practise a couple of times before you get out there to get the hang of it before you stall in traffic. ;)
  7. 2door
    2door Moderator
    Staff Member
    16,301
    26
    No one is laughing at you, Toothy.
    We older guys sometimes take for granted that everyone knows how to use a clutch when coming to a stop. That's because we learned to drive in standard (manual) transmission cars. We need to keep in mind that there are a couple of generations out there who have never driven one and their only experience is with automatic transmissions.
    Sort of like asking one of the youngsters how to change channels on the TV without a remote.
    Thanks for all the good answers guys. That's why we're here.
  8. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks for all the info....I hope to drop the clutch this weekend. I'm sure I'll be asking a lot of fine tuning questions after that.
  9. dodge dude94
    Jun 8, 2012
    1,017
    Just a word of advice for the first start: If you're riding it without the engine on, about to pop the clutch and something feels ......"off", don't do what I did...STOP! lol
    I about tore my rear wheel apart when my chain idler took a dive into the spokes on my first start, and I had had a weird feeling before it did that too.
  10. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Excellent advice here guys....
    Tom you are so right, we should all take a step back many timea and remember that there was a time when we were all inexperienced and ignorant of some things and because someone else cared enough to share their knowledge we were educated about the things we didn't know.
    This is b far the best forum I've ever had the privilege of being a part of and the reason it's the way it is and so great is because of all the great people that are here and most of all because of the excellent first class Moderators and of course the best Administrator.
    Your in the midst of a great group of people here Toothy and we will help you any way that we can to help you create a safe and reliable motorized bicycle, read read read, and remember the only dumb question is the one not ask especially when it comes to things that can determine safety.
    Best wishes on your bike.
    Map
    .wee.
  11. maniac57
    Oct 8, 2011
    4,486
    I think the best advice I have would be to remember at all times that you are riding a BICYCLE with extreme (for a bike) speed potential and are far outstripping the original design envelope for the machine.
    You need to ride as though it could explode at any second when you're doing more than 10-15 mph....
    Look ahead and ride SUPER defensively. Cagers will look you in the eye and pull right out on you 90% of the time. You are invisible to drivers even when they DO see you because you are moving so much faster than a normal bike.
    Take it easy your first few rides and try things out to see how your bike does at hard braking, swerves, etc. Go find a smooth grassy field to practice on if you're worried about dumping it while learning.. Grass hurts far less than pavement.
    Since you have dirtbike experience, it won't take you long to get the hang of it.
    Think slow single speed dirtbike with skinny knobby tires on pavement and you're fairly close...
  12. Tyler6357
    Tyler6357 Member
    Mar 15, 2012
    823
    13
    My advice is to avoid accelerating while going down hill. There is no need to rev it up when going down hill, you won't gain that much extra speed and you will burn your engine out. It's better to just disengage the motor and maybe peddle once or twice and let the weight of the bike accelerate you down the hill. When you want to re-engage the engine just adjust the throttle depending on your speed and release the clutch handle, you will get the hang of it after a while. Also, ride under the assumption that nobody else on the road can see you because most of the time, they don't.
    #12 Tyler6357, Apr 23, 2014
  13. Toothy
    Toothy New Member
    Mar 25, 2014
    181
    Thanks for that.... I was wondering about riding down hill. Great tips guys / gals.
  14. Techbiker
    Techbiker New Member
    Oct 27, 2009
    165
    I rode my Thatsdax Happy Time 70cc for 350 trouble-free miles. When I sold the bike, the engine still ran without issue.
    I actually really enjoyed having a clutch on my happy time. It was much more fun than the auto clutches on my Huasheng 50cc or GT50R. Feathering the clutch was not too much of a problem for me. I always pedaled to around 7mph before releasing the clutch though.
    Finally, the HT clutch really made me feel more comfortable about driving and shifting a manual car.
    Enjoy the happy time!
