Disguising an engine
Discussion in 'Motorized Bicycle General Discussion' started by mifletz, Apr 15, 2010.
  1. mifletz
    mifletz Member
    Aug 25, 2009
    84
    Can one get away with diguising a driven engine with a thin zip-on nylon bag that allows air through?
    Or will any impeding at all of the air flow cause damaging overheating?
    [​IMG]
    [​IMG]
  2. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    I would'nt use a bag, i would think it would melt. You could try a plastic milk crate which has vent holes, should be easy to mount too.
    #2 Cabinfever1977, Apr 15, 2010
  3. stuartracing
    stuartracing New Member
    Dec 9, 2008
    488
    Sometimes I see these guys down here in FL. wearing those camo. colored shirts and pants and I almost bump into them cause I can`t see them.....Or try painting it camo.colors.It would blend right into the surroundings.....Just kidding...The baskets with the bottom cut out might work good...Zip tie it....
  4. rockhopper
    rockhopper New Member
    Mar 20, 2010
    221
    That's funny! You're not fooling me but how about those paperboy baskets? If you lined them with inner bags with handles that might go a long way towards hiding the engine. At least from the side.
    Or how about a seat post mounted rear rack with panniers?
  5. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,816
    10
    I had been trying to do something similar with my frame mounted engine. I was planning to cover the sides of the engine but leave the front, top and rear open for airflow. I plan to add some spacers between the cooling fins to reduce noise. To further reduce noise, I will use fiberglass wrap in the muffler, make an exhaust extension, and make a baffled air box for the intake.
  6. DOC BOLM
    DOC BOLM New Member
    Aug 21, 2008
    681
    Great plan but how do you DISQUISE the sound,
  7. rockhopper
    Mar 20, 2010
    221
    Air horn.
    cvlt1
  8. metalliatic
    metalliatic New Member
    Mar 14, 2010
    96
    why would you want to hide the motor? maybe you should go electric. no sound and easy to hide.
  9. mifletz
    mifletz Member
    Aug 25, 2009
    84
    Any photos yet of Staton's new "Bicycle Motor Disguise Kit"?!
  10. Catfisher
    Catfisher New Member
    Apr 10, 2010
    134
    I just talked to Staton's yesterday about the saddlebag disguise kit. He told me to not hold my breath, it takes a long time to design and get molds made. He didn't expect anything within six months.
    There was a recent picture of a bike with the rear motor well disguised, I'll try to find it. Anybody else see it?
  11. Bikeguy Joe
    Jan 8, 2008
    11,529
  12. Catfisher
    Apr 10, 2010
    134
    I found it! Here is the best diguised bike with your type of engine I have ever seen. The pictures are quite large, so here is a link to the original thread. When the link opens, scroll down the page and then click on the top of the pic to enlarge it. Very cool looking.
    http://motorbicycling.com/f17/illinois-1341-16.html
    .flg.
  13. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    I think Staton has one of the stelth kits out,beacause I did not notice any motors on any of the bikes today around the neighbor hood
  14. Cabinfever1977
    Mar 23, 2009
    2,290
    Engines are easy to hide but you can't DISQUISE the sound, i was pulled cause cops can here it running, not because they saw anything on the bike.
  15. mifletz
    mifletz Member
    Aug 25, 2009
    84
    Any sign yet of Staton's "stealth kit"?
  16. mifletz
    mifletz Member
    Aug 25, 2009
    84
    If one cut to size a piece of old sacking with holes in it, and carefully sewed and wrapped it round a Robin 35 to disguise its shape, would there still be enough ventilation flowing through the holes to provide sufficient cooling?
    [​IMG]
  17. rustycase
    rustycase Gutter Rider
    May 26, 2011
    2,746
    Nope.
    The burlap is a bad idea.
    Any screen over the motor will hamper cooling.
    If not moving at a decent rate to force air through a cooling duct will be fatal.
    AND
    the burlap fabric will soak up engine fumes and become a combustion point.
    just like a molotov cocktail.
    probly not a gud thing.
    IMO, exhaust noise is first to bring unwanted attention,
    second would be erratic movements in the traffic pattern.
    Third might be NOT dressing as a customary bicyclist.
    Fourth would be a Pnut tank.
    Best
    rc
  18. mifletz
    mifletz Member
    Aug 25, 2009
    84
    What is the easiest way to reduce the exhaust note of a Robin 35?
  19. rustycase
    May 26, 2011
    2,746
    Maybe a little bit of steel wool, scrubby pads... stuffed into a soup can, added onto existing exhaust pipe?????
    don't pack it in tite... leave it loose to avoid creating too much back pressure.
    Or u can make a glass-pack with some fiber-glass insulation wrapped around a piece of hardware cloth, inserted into a length of tube...
    good luck
    rc
  20. Ibedayank
    Ibedayank New Member
    Oct 29, 2011
    1,171
