Disc Brake Suggestions
Discussion in 'Motorized Bicycle General Discussion' started by chainmaker, May 30, 2010.
  1. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
    I am looking for suggestions on a decent set of 160 mm Disc brakes that are somewhat wallet friendly.
    Cheers
    Chainmaker
  2. Dave31
    Dave31 Moderator
    Staff Member
    Mar 1, 2008
    11,207
    14
    I used the Tektro Aquila and was very happy with them. I think they were around $60 (Disc, caliper, cable and lever kit) but I scored a sweet deal for $35.
  3. Venice Motor Bikes
    Mar 20, 2008
    6,170
    I sell the whole set up, including the mounting bracket & hub for $100. (no lever.)
  4. taddthewadd
    taddthewadd New Member
    Mar 1, 2009
    339
    I like the type where on the caliper both pads have an adjustment. It makes it way easier to tune the setup. Some calipers only have an adjustment on the outside pad.
  5. dag_29307
    dag_29307 New Member
    Jul 1, 2009
    296
    this is something that has intrigued me. Do you have to have a "special" type of frame/fork to use disk brakes or can you install them on "any" bike? I am on a strict budget and also need information too.
    Do you mean the forks and the brakes for $100.00 And I take for granted ( no lever ) means no brake handle right? Or is there another lever I don't know about.
    #5 dag_29307, May 30, 2010
  6. Fabian
    Fabian New Member
    Sep 9, 2009
    168
    My personal opinion from having gone through this process before:
    Don't waste your time with 160mm disks.
    Go straight for a Shimano 203mm disk and use the Avid BB7 mechanical caliper - makes for a very good combination.
    Fabian
  7. taddthewadd
    Mar 1, 2009
    339
    The avid bb7 is the one with an adjustment on both brake pads. Much better than the cheaper bb5
  8. Technocyclist
    Technocyclist Motorized Bicycle Senior Technologist
    Jul 7, 2008
    463
    Tektro works for me. Well, my front is Tektro, and my rear is Avid. I have replaced my pads in Avid 3 times already, and have still yet to replace pads in the Tektro. Both are mechanical... :)
  9. Venice Motor Bikes
    Mar 20, 2008
    6,170
    What I sell for $100. is the disc brake hub, rotor, caliper, caliper adapter that works on any fork & all the screws to bolt it together. You need to buy a cable & lever of your choice.
  10. dag_29307
    Jul 1, 2009
    296
    These will work on "any" forks? they don't need to have a special mounting tab welded on or anything? Then if the answer is yes, as soon as my broke butt can get $100.00 We will do business.
  11. Venice Motor Bikes
    Mar 20, 2008
    6,170
    Yes, I make a mounting bracket that works on any fork.
