Detailed Instructions?
Discussion in 'Motorized Bicycle General Discussion' started by maxsideburn, May 24, 2011.
  1. maxsideburn
    maxsideburn New Member
    Dec 7, 2009
    103
    Ok, putting together my BGF kit and I must say that there are a ton of little parts that I have no idea where they go or what they are used for.
    Are there any detailed instructions out there that actually go into the details? Everything I've seen simply says "Mount Engine", or "Assemble Clutch Lever" but doesn't go into detail about what all of the little nuts, bolts, springs, brackets, etc... actually are and where they go.
    For instance, my throttle assembly is together and on the bike, I have the cable run into it...but I have to manually turn it each way, there's no "spring return", so obviously I'm missing a spring or something. I know the throttle is supposed to close by itself when you let go of it but it doesn't.
    Thanks.
  2. biknut
    biknut Active Member
    Sep 28, 2010
    6,379
    The throttle return spring is inside the carb. If your throttle doesn't return, it's probably because of a tight fit between the throttle grip, and the handlebar. In other words the throttle handle is rubbing on the handlebars and hanging up. You may need to lightly sand down the handlebars where the throttle fits. It also might help to apply a little grease to the inside of the throttle handle.
  3. maxsideburn
    Dec 7, 2009
    103
    no, it's not even hooked up to the carb yet...I just figured there should be a spring inside the throttle assembly itself to return the throttle to closed automatically. without it the assembly feels extremely cheap and chintzy.
  4. biknut
    Sep 28, 2010
    6,379
    It'll feel a lot different after you get it all assembled.
  5. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Try this and see if doesn't help a little > Page Title
  6. DaveC
    DaveC Member
    Jul 14, 2010
    970
    That pretty much describes the Chinee motor bike engine.
    Could not have said it better myself ;)
  7. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    Didn't BGF email you his assembly .pdf?
  8. maxsideburn
    Dec 7, 2009
    103
    yes...and his assembly PDF has the vaguest instructions I could possibly imagine. I'm talking about a layout of each and every single part, where every nut, bolt, washer, etc.. is supposed to go, all with high-res images (not 200px pictures that are beyond useless).
  9. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    laff
    Don't hold your breath.
  10. maxsideburn
    Dec 7, 2009
    103
    wow, that's sad. so many people have built these things and nobody has taken the time to make a very detailed write-up?
    next time I build a bike I will have to do that ;)
  11. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Max, that would be an awesome contribution to the community and would be welcomed and applauded!
    If I can in any way help, lemme know. In trying to help folks with 1st builds, a big part is the confidence part. A kind, well worded and pictured "how-2" would be really great.
    Indigenousness children will sing your praises!
    I have tried 2ce to get a collaboration going to do just that. I have great luck building but have some unorthodox methods. (I regularly take short cuts, use steel toed work boots and pretty much cheat) So I could not be trusted to offer a sound way of doing some things. But am there big time.
    Ya gotta do this!
    .flg.
  12. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    More power to ya!
    It is an enormous task, as there are so many bikes out there.
    Custom fitting is always required, so a precise assembly with a perfect parts kit will always be impossible unless the bike fits the motor to a "T".
    You know, the perfect angle with the perfect pipe diameters.
    And that doesn't cover the chainstays and seatstays and tire/chain hits.
    All you can do is post what works for you.
  13. dag_29307
    dag_29307 New Member
    Jul 1, 2009
    296
    Aren't there a couple of video's on this very subject on Youtube?
    Here's the best one I found yet...http://www.youtube.com/watch?v=bW8nAvOSntM&feature=related...The volume is a little low but he is very clear in what he says and is very thorough. Yeah, it doesn't cover "Every" bike but it gives a really good idea.
    #13 dag_29307, May 27, 2011
  14. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Cool Dag. post em all
