Delmar Cruiser Question?
Discussion in 'Motorized Cruiser Bicycles' started by lmmacko, May 17, 2011.
  1. lmmacko
    lmmacko New Member
    May 10, 2011
    13
  2. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    That is a good bike to use considering that it is a cantilever frame design.
    Do a forum specific search on "Del Mar" for more info.
    That said, beware of the fenders!
    http://motorbicycling.com/f3/walmart-schwinn-cheap-18059-3.html#post175122
    http://motorbicycling.com/f11/another-tale-fender-failure-10191.html
    http://motorbicycling.com/f11/fender-fixes-tip-bairdco-industries-14032.html
    http://motorbicycling.com/f3/one-time-i-impulse-buy-chinese-23958-2.html#post223024
    http://motorbicycling.com/f41/stock-fenders-reinforcing-22786.html
    There are plenty more posts on the subject if you feel like doing a search.
    Also, I cannot stress how important it is to clean and repack the wheel bearings with good quality automotive grease before you put any kind of strain or speeds that bolting an engine into it can do. The factory grease is junk. It is also a good idea to clean and repack the pedal crank and fork neck/ steering bearings with the same quality grease while you are at it.
    Any bike worth upgrading with an engine needs to be taken care of properly to endure the extra strains and stresses of engine power.
  3. lmmacko
    lmmacko New Member
    May 10, 2011
    13
    Thanks a lot. I'll take a look at the links.
  4. treyoh5
    treyoh5 New Member
    Apr 29, 2011
    36
    [​IMG]
    youre gonna have to reinforce the fenders so they dont come loose and entangle into your spokes, rear fender has to be *slightly modded to clear the drive chain, mufflr has to be bent inwards *slightly to clear the pedals and youre gonna need a universal bracket for the large downtube for the front engine mount.
    cheers.
    almost forgot i had to buy a thinner rear wheel (26x1.75) due to chain rubbin
  5. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,849
    60
    I didn't build one but one of my friends did, be sure to get the sprocket spaced over correctly so the chain does not rub the tire.
  6. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
  7. F_Rod81
    F_Rod81 Dealer
    Jan 1, 2011
    1,033
    My friend had one and the frame snapped just in front of the seat down tube. He does weigh close to 200 lbs, IDK if it is a flaw with the model, or just with that particular bike. Now he has a cranbrook
