Debate on best fuel to oil ratio
Discussion in 'Motorized Bicycle General Discussion' started by Bigredgasbike, Nov 28, 2010.
  1. Bigredgasbike
    Bigredgasbike New Member
    Apr 2, 2010
    50
    Ive been researching the best fuel to oil ratio for getting the most speed out of my bike, and havent come up with much, so i decided to ask you guys. Anyone have an opinion, or suggestion on the best fuel to oil ratio for the best speed and efficiency for a motorbike?xct2.wee.
  2. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    Well it depends on the bike. Run half a tank of 30:1, check the colour of the plug. If it's black brown/covered in unburnt oil, up the ratio to 35:1 or so. If it's grey in the centre, you're running lean and need to put hte ratio down. You want a chocolate brown colour.
  3. Bigredgasbike
    Apr 2, 2010
    50
    ill do that then post back, thanks for the input =)
  4. biknut
    biknut Active Member
    Sep 28, 2010
    6,365
    If I were you I would follow the directions of the oil manufacturer, and buy a good synthetic oil.
  5. scotto-
    Jun 3, 2010
    6,527
    Uhhhh, the best ratio I've found so far is none.....get a 4-stroke. It takes the guess work out of mixing ratios completely....... plain and simple.
  6. bairdco
    Aug 18, 2009
    6,333
    19
  7. WayneC
    WayneC New Member
    Aug 2, 2009
    173
    Hmmmm
    If it's a question of speed, I don't think your ratio is gonna do much to help you go faster. Oil is about lubrication, wear, and internal protection; not how fast it will make you go.
    I agree with Bairdco tho, check out Opti-2
  8. yodar
    yodar New Member
    Jul 26, 2010
    147
    I have a different version of the question. I am using AMSOIL 2-stroke oil at 100:1 and I have no complaints.
    BUT I HAVE a quart of Amsoil 10-30 synthetic automobile motor oil. What should I dilute IT at?
    I KNOW the Chinese use strait 30W motor oil. What do they dilute it at?
    yodar
  9. ferball
    ferball New Member
    Apr 8, 2010
    599
    There was a post a few months back where some one was running 10w30 at 16:1 with moderate success very well documented and full of good info.
