cvt vs. clutch 2 jack shaft?
Discussion in 'Motorized Bicycle Welding, Fabrication and Paintin' started by halfevil333, Jun 11, 2011.
  1. halfevil333
    halfevil333 New Member
    May 18, 2010
    307
    has anyone tried running your 4stroke w/a clutch to jackshaft straight linkage as opposed to a cvt?
    ...and, if so, hows that running for you?
    I'm thinking I like the simplicity of the setup- not to mention significant savings!
  2. culvercityclassic
    culvercityclassic Well-Known Member
    Sep 27, 2009
    3,084
    55
    Not much savings, you will love the operation of a cvt...trust me
  3. wilrod
    wilrod New Member
    Jul 20, 2011
    42
    please translate what is a " c v t " ken
  4. killercanuck
    killercanuck New Member
    Dec 17, 2009
    1,749
    cvt- continuously variable transmission, Like a Nexus hub? or snowmobile type pully? I forget.
  5. irishpowerjunkie
    Jan 24, 2012
    115
    i am currently trying your idea myself in a diy custom build with strimmer engine, please keep post if it works,I will try to post picture when finished building.xx.
  6. Ibedayank
    Ibedayank New Member
    Oct 29, 2011
    1,171
    your a CANUCK and you dont know this... laff
    and a cvt is what snowmobiles use and have used for over 60 years
    bike with a cvt..... http://www.youtube.com/watch?v=V2aFd3x7Vms
    owner is a member on this forum
    #6 Ibedayank, Feb 7, 2012
  7. curtisfox
    curtisfox Well-Known Member
    Dec 29, 2008
    4,119
    52
    It depends on what 4 stroke you plan to run, some of the small 50cc run up to 8,000 rpm's and then you need to put the clutch on the jack shaft like the 4G kits. Other then that you can put a regular clutch on the engine and run to a jack shaft then back to the wheel. That is usually the best because you can change the pullys or sprokets that way to change ratio. In fact you don't even need a clutch you can do a belt tightener like lawn mowers have............Curt
    #7 curtisfox, Feb 7, 2012
