custom frame cruiser..honda powered
Discussion in 'Motorized Cruiser Bicycles' started by Dagwood, Oct 8, 2011.
  1. Dagwood
    Dagwood New Member
    Aug 4, 2011
    70
    Had this in another forum ( BT's and vintage etc)..not sure if it should be there..or here..so heres a few pics. my first build...learned alot..now about ready for the second!
  2. Fulltimer
    Fulltimer New Member
    Aug 13, 2010
    1,322
    I don't see any pedals.
    Terry
  3. Dagwood
    Dagwood New Member
    Aug 4, 2011
    70
    No pedals Terry..I put a honda on it..didnt figure I needed them. If I had used one of those cheap china engines..I no doubt would need pedals for backup.
    One thing I have discovered however I did not anticipate..the high frequency vibrations Very hiog freq..like ..a barbers clippers on the back of your neck..so yesterday I spent tearing it apart and making antivibe mounts for the engine to isolate the vibes..I used Barry mounts and they worked very well. Smooth as silk now..no tingle butt!
    #3 Dagwood, Oct 10, 2011
  4. LS614
    LS614 Active Member
    Dec 22, 2009
    1,236
    That is a very strange look but I like it a lot! Looks like a blast! What kind of speed do you get with that system? Also, is that a staton box? peace
    -Luke
  5. azbill
    azbill Active Member
    May 18, 2008
    3,367
    what drive is that ???
    looks pretty stout :)
  6. MotorBicycleRacing
    Jul 28, 2010
    5,738
    40
    It's a Staton "wheelbarrow" 18:1 gearbox configured as an inside drive.
    Lance Portnoff uses the same gearbox on his Design Logic bikes.
  7. Dagwood
    Dagwood New Member
    Aug 4, 2011
    70
    Yup..I used the Staton 18.75: 1 gear reduction...18 tooth sprocket on the output. 44 on the hub. Gives a top speed of about 16mph....but the key is..the clutch is fully engaged at about 5 mph...so it goes slow real well, without slipping the clutch..which would be a real problem with a higher ratio for more top end. The Machine is not a commutor..but a "campground bike" so to speak...and seldom will speeds exceed 10 -12 mph...its perfect for the mission intended..and I think the Honda/Staton combo will be pretty well bullet-proof. Which was the top priority anyway..cause my wife will be riding it! Since these pics..I re-did the engine mounting, and have added 3 barry mounts to eliminate the vibration..which I really did not anticipate..pics on that in the "mounting section" . Worked perfectly..just about zero vibration thru the seat, bars and footrests now.
  8. LS614
    LS614 Active Member
    Dec 22, 2009
    1,236
    very cool, it must be a real crawler with that ratio huh? Climbing any trees? lol Camp ground bikes are great when you're just to tired to pedal so I totally get it :) great job, should last you a LONG time :)
  9. Dagwood
    Dagwood New Member
    Aug 4, 2011
    70
    with new engine mounts and tank..basket and about done...I think!
